First post, by Excelsior
I recently received 2 motherboards (ASUS P4P800 and Gigabyte 7VT600).
Both motherboards look fine, there are no burnt traces or IC missing or destroyed, all capacitors seem ok but neither of the motherboards post. There were used by a friend of mine many years ago in office computers and the motherboards were working normally when he removed them from the computers but they were kept several years in drawers.
I tried with functional and different memories, processors, power supplies and video cards but the result is the same.
The coolers start spinning but there is no image on the monitor.
Since all other exterior factors have been eliminated it seems that the only cause is the motherboard.
Is it possible that one or several capacitors might be actually dead even if they look normal at exterior? Is there a way to check each capacitor?
Thank you!
Reply 1 of 13, by Daniël Oosterhuis
Have the BIOS ROMs been checked?
Long term lack of powering up EEPROMs can cause the contents to bit rot, several video cards of that era need reflashing to work again.
Hard to say if it is just the caps.
I would do further diagnosis with something like a POST code card first before jumping to conclusions.
Reply 2 of 13, by Tetrium
Excelsior wrote on 2023-07-03, 09:13:
ASUS P4P800
I hope for you it's not the south bridge (flawed USB ESD protection design).
My retro rigs (old topic)
Report spammers here!
Reply 3 of 13, by Roman555
Check temperature (I'm using just my finger) of south bridges (and maybe other chips) - they shouldn't be scorching hot.
If you upload hi-res photos maybe someone will spot something wrong.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 4 of 13, by Doornkaat
+1 for reflashing BIOS EEPROMS.
It is entirely possible for capacitors to look intact but be defective. They can only be reliably checked out of circuit unfortunately.😐
Reply 5 of 13, by Excelsior
Roman555 wrote on 2023-07-03, 11:32:
Hi, Check temperature (I'm using just my finger) of south bridges (and maybe other chips) - they shouldn't be scorching hot. If […]
The southbridges are a little warm but that's all, not hot at all.
https://imgur.com/a/8PJLbZ0
Reply 6 of 13, by Roman555
Excelsior wrote on 2023-07-03, 13:17:
It looks pretty good. Try to run the mainboard without RAM. It should beep. A PCI debug card is usually helpful in such cases.
Also check voltage of a CMOS battery and replace if it's lower than 3v. I doubt it will help but it's worth to try.
If you have a multimeter you can make some measurement: CPU core voltage, bridges voltage
Schematic manual GA-7VT600 (a different rev. but it's better than nothing)
    164.53 KiB
    Is a MOSFET damaged?
Reply 7 of 13, by Excelsior
Roman555 wrote on 2023-07-03, 16:24:
It looks pretty good. Try to run the mainboard without RAM. It should beep. A PCI debug card is usually helpful in such cases. A […]
I tried without RAM, without video card, only with the processor but there was no beep.
However every time the system starts there is an almost inaudible sound like a click but it is very faint, you have to be close to computer to hear it.
There was only a little dust on the MOSFET but no damage, I cleaned with a piece of paper and it is now like new. The battery is new and I also tried with other batteries but there was no change.
Thank you for the suggestions, I will check the voltages.
Reply 8 of 13, by shevalier
Regarding 7VT600.
Check the die of the CPU, it is quite fragile.
It could be damaged even during transportation with a slight distortion of the cooler position.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 10 of 13, by rasz_pl
Excelsior wrote on 2023-07-03, 19:17:
that click is often a short on the motherboard, if power supply keeps shuts down its one of main rails, if it keeps going its cpu/ram power converters
both boards are from the middle of cap plague, might even worked when put away but dried since then
Reply 11 of 13, by Excelsior
After eliminating all other possibles causes (ICs, traces etc.) it seems that the only remaining causes are either the southbridges or the capacitors. The boards themselves look good and no exterior hint is visible on them.
The problem is that all the capacitors look normal, there are no bulged or leaking capacitors.
Is it possible that one or several capacitors are in fact dead/dried even if they look normal at exterior?
If so what is the best solution: replacing all the capacitors on the boards or only replacing the most likely problem making capacitors? Which ones are the most likely to be dead - those near the CPU sockets?
If the southbridges are the problem then there is nothing that can be done. But in this case when the systems are powered the southbridges are only a little warm, not hot and not cold. And they remain a little warm as long as the systems are powered-on, so it seems that the southbridges might not be the problem.
Reply 12 of 13, by PcBytes
Check the die on the P4P800's northbridge.
I know it sounds weird but I had a Gigabyte 8IPE1000-G not POST, SB was normally warm (as in, not too hot to the touch) but no POST or any activity. Come to remove the NB heatsink and notice the chipset die had a microscopic hole in it. In hindsight, it should've dawned on me NB was bad as it was getting unusually hot.
Reply 13 of 13, by rasz_pl
"looking" at electronics doesnt eliminate anything. You mentioned checking voltages, but didnt follow up. You say everything looks great yet Roman555 and Karbist found cracked components
