First post, by GoldenPentium
Hi,
I accidentially learned that my Lucky Star 5I-VX2B motherboard missing 5v - I measured only 4.12-4.19 on PCI 5v pins. I suspect that's the reason that my Intel PRO/100 Management adapter isn't working on particular this board, but works just fine on other boards (486, SE440BX, WS440FX). All other components also work fine on that mobo - CPU (P233 MMX), PCI videocards & diagnostic adapter, etc... PSU outputs 4.93-4.95v, it correctly works with other motherboards, too. Another one observation - 5v wires (left 3 if look on top) are hot - not critical, I guess, but I didn't notice the same on 486 board, with the same ATX-AT adapter.
Where should I look to uncover that mistery?
Thank you.
Reply 1 of 7, by Sphere478
Little confused. Are you talking about negative five volts? This is usually only needed on some isa sound cards.
Changing to a psu that has it is the easiest way.
Other options are voltage blaster (everyone’s favorite auction site), or pico psu adapter (see sig)
I haven’t heard of the issue affecting pci cards though, I’m trying to remember if -5v is even on pci? I know -12v is.
Edit:
https://pinoutguide.com/Slots/PCI_pinout.shtml
Don’t see -5v unless I am blind.
Your problem may be lack of 3.3v
In which case, see the thread “adding 3.3v to pci”
Sphere's PCB projects.
Reply 2 of 7, by GoldenPentium
No, +5v to PCI. There is only 4.12-4.19v, but on other board - 4.93-4.95v.
Reply 3 of 7, by Sphere478
Change your psu. That voltage is probably directly from the psu.
See my edit.
Your woes are likely from incompatible pci version or lack of 3.3v on pci slots. Some bios settings can affect compatibility sometimes.
Reply 4 of 7, by weedeewee
GoldenPentium wrote on 2023-07-05, 01:26:
Thank you.
Are some of the Mainboard psu connector pins corroded by any chance ? That would easily explain the observed behaviour. voltage drop and heating up of wires.
Since you mention the psu working on another mainboard, I exclude the psu connector. Though heating up of the connection tends to be a bad thing. you might want to inspect the psu connector as well for any possible damage to the pins.
Do not ask Why !
Reply 5 of 7, by jmarsh
If the voltage is drooping and the plug is hot (= lots of current being pulled through it) something has probably shorted or very close to it. Disconnect the PSU, measure resistance between 5V and GND on the motherboard.
Reply 6 of 7, by Sphere478
jmarsh wrote on 2023-07-05, 04:26:
Might be crappy psu with tiny guage wires?
The computer wouldn’t boot at all if there was a dead short on the 5v
I suspect the network card problem may be a separate issue. Probably pci version, or lack of 3.3v
The 5v behavior observed is probably from a lot of cards being installed and a cheap psu.
Time will tell, OP will let us know by thread’s end 😀
Reply 7 of 7, by lti
Thin wires could be the problem, but in the mentioned ATX to AT adapter instead of the PSU itself. I've even seen wires made of unknown high-resistance metal that was copper-colored all the way through (not CCA - the resistance was too high for even aluminum). That Pentium MMX will draw more power than a 486, and using a linear regulator for the VRM means that the 5V current will be higher than a socket 7 motherboard with a switching VRM.
It depends on where you're measuring 5V. If you probe the AT power connector (assuming you have thin enough multimeter probes to fit in the wire end of the connector) and get the correct 5V, then the problem is in the connector. If you're still only getting 4V, then it's the adapter.
