First post, by GoldenPentium
I accidentially learned that my Lucky Star 5I-VX2B motherboard missing 5v - I measured only 4.12-4.19 on PCI 5v pins. I suspect that's the reason that my Intel PRO/100 Management adapter isn't working on particular this board, but works just fine on other boards (486, SE440BX, WS440FX). All other components also work fine on that mobo - CPU (P233 MMX), PCI videocards & diagnostic adapter, etc... PSU outputs 4.93-4.95v, it correctly works with other motherboards, too. Another one observation - 5v wires (left 3 if look on top) are hot - not critical, I guess, but I didn't notice the same on 486 board, with the same ATX-AT adapter.
Where should I look to uncover that mistery?
Thank you.
