First post, by LSS10999
I'm currently struggling to get my FirePro 2260 PCI video card working correctly on a XP system. It's a PCI video card with two fully-capable DP1.1 ports.
Drivers that I could find simply don't appear to work correctly with my monitor, ROG XG27UQR, on Windows XP.
Should note that there's nothing wrong with the cables used here, as when booting into Linux (EndeavourOS for example), the card can output 1440p/60Hz and 1080p/120Hz perfectly fine. It's a driver issue.
-x- Official driver package (8.911.3.4)
Does not work at all. I get a black screen (OSD saying NO SIGNAL). Booting to VGA mode will give me an initial 640x480 screen (from the default system driver, as CCC would refuse to run in this state citing unsupported driver), but selecting any mode will irreversibly lead to a black screen, as it switches to using the ATI driver which gives me no output at all.
I cannot uninstall the driver from Safe Mode. Must boot into VGA mode (which is considered normal mode) in order to perform uninstall, as the uninstaller relies on a detection driver that refuses to load in Safe Mode.
-o- Driver package found at Phil's Computer Lab (8.583)
I can get a screen output, though very blurry. OSD reads 1440x576, but that particular resolution is not available in the settings.
Only by setting DP version to 1.1 can I get a proper output. Setting it to any other version (1.2, 1.4) will result in the blurry, actually 1440x576 output. I do not want to change my monitor's DP version, as it is shared by some other systems that are fully capable of using DP 1.4.
CCC will give me a "DisplayPort Lower Setting Applied" warning every time I try changing resolution. I can only set up to 1080p/60Hz as a result of this warning, even with DP version set to 1.1 (which allows proper output).
Where can I find other driver versions to try? Googled and even DuckDuckGo'd everywhere but no good results... Most results seem to point me to Vista/Win7 drivers...
PS: I'm not sure which variant I got... GPU-Z tells me that my card is 1002:95CE/1002:2343, but all of the video BIOS I found on TPU related to this card read 1002:95CF/1002:2143 which appears to be a Dell variant. Drivers do correctly recognize my card as a FirePro 2260, and the google search results I get appear to confirm that both 95CE and 95CF are indeed for FirePro 2260.
