Reply 100 of 162, by doublebuffer
appiah4 wrote on 2023-08-02, 08:08:Doesn't the MİSTer basically do this already?
No, it's too slow to emulate PC correctly. The ao486 core is basically abandoned at this point, the dev lost interest to improve it. It does run games but it isn't hardware-correct, it takes shortcuts to simplify the emulation sacrificing correctness, it's basically just a glorified dosbox. It was the very reason I got into real hardware, because I understood there is simply no modern solution which would be able to replicate everything I wanted.
EDIT: I'm drunk
