First post, by Oldskoolmaniac
First off it's been a long time since posting here a lot has changed since 2018 some posts are gone, some people banned. I just back into collecting again after selling of everything. Despite all of that how is everyone doing?
I just recently acquired two identical ibm aptiva 2137 E26 towers. I'm trying to find a more recent bios then the one found here http://web.archive.org/web/20041122034144/htt … MYS-3SNRT3.html also looking for a chipset driver that works under windows 95 the drivers on phils website doesn't work for me.
Most websites are stating that the max cache ram is 64, but having 64mb seems a little slower then when i had 128mb of ram.
Specs:
233mhz k6
64mb of ram single stick
8gb cf
onboard ati rage IIc
313.43 KiB
85.78 KiB
303.74 KiB
491.93 KiB
320.06 KiB
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 1 of 4, by Horun
The E26fix is the latest AFAIK, and the ALI drivers in Vogons Library should work:
http://vogonsdrivers.com/getfile.php?fileid=1047&menustate=0
and http://vogonsdrivers.com/getfile.php?fileid=1074&menustate=0
Reply 2 of 4, by Oldskoolmaniac
Thanks the second link worked. I think the e26fix is going to be latest bios that I'm going to find.
Reply 3 of 4, by Horun
Great ! Glad you got it working.
Reply 4 of 4, by Oldskoolmaniac
After looking up more info on the chipset I found here https://www.anandtech.com/show/72/2 that it can cache up to 512mb of ram with 11-bit Tag now where would i be able to search for that type of ram?
