I have five CRT Devices and I love em' all, but I'm going to be running them until they truly die past a point of me replacing them.
For TVs I'm using a Rhapsody 5" CRT Portable for fun little shennanigans. When it's not running, it's on display. I mostly use it with my Atari 2600. It's funny because the ATARI can act as a TV stand for it, 🤣.
The other TV is a huge, 27" 1989, Mitsubishi CS-2720R with RCA Passthrough (so Let's Play with a CRT for my acutal monitor). It needs a recap, but the picture tube and picture quality (when properly degaussed) sis to DIE FOR. Crisp, sharp, but just enough of that CRT goodness that everything looks as the programmer/designer intended. Youtube, even squeezed, looks as good as my 4K UHD TV. It's like Bithead1000 stole NBC's studio equipment for a Cable Access show!
I have three CRT monitors, unfortunatley my KDS was destroyed.
14" NEC MultiSync II JC-1402-HWA - This is the one I'm using right now. THis was a rescue from a recycle bin and it's held together by bodge wires and lunacy, but somehow, it's REALLY perked up, it seems all of the caps have fully reformed over the past 7 years. When I got it, it was dim, the focus and voltage had to be cranked to look good, everything had a weird almost yellowish hue to it. Now in 2023 it's sharp, crisp, has perfect whites, and the low dot-pitch makes DOS games look frickin' incredible on it regardless of whether they are CGA, EGA, or VGA. It also does high resolution SVGA modes, I got it up to 1024x768 using WD Data Lifeguard (one of the DDOs I use) and while the text was hard to read the picture was incredible for a monitor built in 1988. This is my most priced computer CRT.
15" Micron SVGA w/ Digital Controls - Still a little dim, might need to run it more, maybe it'll perk up like the NEC.
17" Dell - Crisp, Bright, Looks amazing on my 2MB VLB 486, especially in Windows 95. I need to fix the stand though. However, the monitor itself might be what I'll have to start using as my eyes deteriorate as I get older.
The aggravating thing to me about CRTs is the fact that when they die, finding an appropriate recycling channel is almost impossible. So it's only worth it to revive them, or keep them until you're brave enough and armed with enough knowledge to fix them at this point, and then give it away if you want to get out of the "CRT game".
The thing I like about them though is all the games and software of the 80's and 90's look the way I remember it, and looks a lot more vivid and lively compared to an LCD monitor. Plus there's something special about seeing a vintage system with a nice glass globe on top shining brightly. Plus I still play original NES Games with a Zapper so I NEED A CRT to play those.
