First post, by disaster
Hello again 😀
Another interesting piece of hardware here.
Basically SCSI internal/external controller + 1 IDE connector (so 2 drives) + 2 FDD connectors (so 4 drives) and of course BIOS included.
I've searching for the model but with no luck.
Picture bellow:
282.16 KiB
Reply 1 of 9, by Horun
The scsi part is same as FD TMC-850. Doubt the dual floppy part will work unless the motherboard bios supports 4 floppies or you use a driver.
No enable/disable for floppy, IDE or scsi so is def an OEM specific adapter.
Reply 2 of 9, by disaster
Horun wrote on 2023-08-12, 23:24:
Yeah SCSI part is common for many FD cards.
Frankly using 4 floppy disks with motherboard does not support it, is quite simple. I've even done this using two regular floppy controllers with different address settings.
All you need is custom ROM in place. You can even put this ROM IC into socket on network adapter card or so.
If I remember correctly there is even software way.
On this particular adapter there is an option to disable HDC or FDC on board. There are jumper above BIOS IC.
Anyway I still wonder what model of card is this? 😀
Reply 3 of 9, by Horun
Thanks I did miss those two jumpers for FDD/HDD enable. The scsi chip TMC950 was used on TMC850 series controllers and if you choose low IRQ (2,3 or 5) can be used in a 8bit XT slot.
Is there any marking on the back of the card ?
Reply 4 of 9, by disaster
Horun wrote on 2023-08-13, 15:28:
Only chinese stamp and serial number CI20002039.
Reply 5 of 9, by HanSolo
Coincidentally I bought the same card some weeks ago 😀 With box, but I think it's only a reseller. The box says 'SIL-5300' by the company 'Silicon'. The booklet says 'CI-2000 SIF'. SIF apparently stands for 'SCSI, IDE, Floppy', CI-2000 matches your serial number.
I even have the disk with driver for four disk drives. Unfortunately at the moment I have no system running with a 5.25" drive so if you want that you have to be patient.
Reply 6 of 9, by disaster
HanSolo wrote on 2023-08-13, 16:46:
That's nice coincident 😀
Patience is my second name so I will appreciate disks images whenever you will get them 😁
Reply 7 of 9, by Grzyb
I've got a similar card - can't check it right now, but likely it's the same model, only without the IDE connector.
And I got it bundled with 16 diskettes:
2 x FDC-OS/2
2 x XENIX
2 x FDU-CD
2 x NOVELL 286
2 x NETWARE 386
2 x SETUP
3 x THE DISK MAESTRO
1 x PowerSCSI!
    fdscsi.rar
    2.04 MiB
    31 downloads
Reply 9 of 9, by Horun
Grzyb wrote on 2023-08-13, 17:43:
I've got a similar card - can't check it right now, but likely it's the same model, only without the IDE connector. And I got it […]
2 x FDC-OS/2
2 x XENIX
2 x FDU-CD
2 x NOVELL 286
2 x NETWARE 386
2 x SETUP
1 x PowerSCSI!
Thanks ! saved it with some pictures of the controller to my FD archives. Thinking it would be a good upload to the library as the readme's mention
TMC 1660, 1680 and TMC 850, 860, 875, 885. plus motherboards with TMC-1800/TMC-950 built in...
