First post, by Vendest
I recently build a computer with four floppy drives using the Quad-Flop ISA card.
While it took me some time to set it properly (due to lack of knowledge at my end), the controller card works wonders and allows me to manage multiple disk format on a single computer.
The card works fine in MS-DOS 6.22, however my initial set up was using Windows 95 (4.00.950 B) on a socket 7/MMX and I had hoped to keep using Win95 for ease of file management and other convenient features.
While Win95 loads, an error shows up as follows.
"While initializing device IOS :
Windows protection error. You need to restart your computer"
In Win95 "safe mode" all drives initialize later and therefore can work as intended.
I wonder if there a setting that can be adjusted to make the OS initialize correctly?
Thanks
