Reply 60 of 90, by SavageKurtain
asdf53 wrote on 2023-09-03, 12:07:Can you press "H" to open the help screen in sjgplay? The help screen also contains some info about the CD (drive letter and CD […]
Can you press "H" to open the help screen in sjgplay? The help screen also contains some info about the CD (drive letter and CD ID number). If this is missing, it would mean that it could not detect your CD drive. Edit: Sorry, I have now read that help screen does not work for you.
What is the output of "DEVICE=vide-cdd.sys " in your config.sys? Press F8 to bring up the Windows 98 start menu at boot, then choose "Confirmation" mode. I don't remember what it is called exactly, but this mode allows you to step through the lines in config.sys and see possible error messages.
Can you list the directory contents of a normal CD-ROM with "dir"?
You could also try another DOS CD driver, oakcdrom.sys is another popular one. I found it here: https://archive.org/details/dosdrivers
And you could try different versions of the VIA DOS drivers, available here: https://archive.org/details/via_dos_audio (I used version 1.11).
Thanks a lot! Really, man, you are saving my life with all of this!
I will try later if it will work, because now i am a bit busy. Thanks again, and thanks to all the people that helped 😀
EDIT: I can list the directory contents of a CD-ROM with "dir".
