Reply 20 of 22, by Rav
janoosh wrote on 2023-10-20, 18:10:So couple of questions to finish this long post off: 1. I still have one PCI and one ISA slots available (2x ISA if I don't use […]
1. I still have one PCI and one ISA slots available (2x ISA if I don't use that PCI). Are there any expansion cards which would compliment this already weird build well? I was thinking about getting a USB 2.0 card to speed up file transfers, as someone earlier in this thread suggested, but if I get network going I don't think I will need one.
2. I'm thinking about getting an L2 cache upgrade as well. From what I know, upgrading from 256k to 512k should not really be a noticeable improvement, so mostly I want to do it just for fun. The manual for this board says the following:
>WARNING: If the cache module that you install already have an extended tag, do
>not install another TAG SRAM into the TAG SRAM Upgrade Socket.
Is there a way to tell if a cache module has an extended TAG on it? On local auction sites I can find a couple of these modules, but at most they are described as 256k cache module, so no details about TAG. Don't want to buy one blindly and accidentally damage my board that way, if it's even possible.I also have one 5.25 inch bay free, but I think I can figure something interesting to put in there myself. Sorry for a long post, I had to gather my thoughts about this whole process somewhere.
1 - A DXR2 mpeg decoder card maybe? Assuming you can also get a DVD drive : https://www.ebay.com/itm/325639929169 . With that you can play your old DVD movies.
You do need another VGA pass-through cable like on the voodoo.
