First post, by holoprox
does NOT work on ATX power!
RESET does NOT work!
boots up to post code 31:
YouTube video [8sec.]
https://youtu.be/h0f68Ra-9lI
tried with many CPU-s, many Video Cards, many ram modules
now using cacheless Celeron 266, 32 PC-100 SDRAM, matrox G100A
any suggestions are wellcome!
100+ retro computers on board!
50+ flightsticks!
Reply 3 of 6, by holoprox
I use the same ATX PSU with and without ATX2AT adapter to P8/P9
As native ATX it does not start using momentary switch.
Did You watch the video?
Measured all the 6.3v/1500uF caps behind the CPU — all good (over 1500 uF) 8,5mF altogether, tested also 6.3V/1000uF caps - all good.
Tried 3 bioses (using external programmer) - same result!
Veeery picky over the Video Card — prefers matrox and ati, with all others posts to 0D or 0E AWARD CODE! Stops at detecting video card!
50+ flightsticks!
Reply 5 of 6, by PC Hoarder Patrol
holoprox wrote on 2023-12-19, 10:05:
I use the same ATX PSU with and without ATX2AT adapter to P8/P9 As native ATX it does not start using momentary switch. Did You […]
Nothing obvious stood out from the vid 🙁 - do your POST card codes tie in with Totems own OB Smart Debug LED codes - https://web.archive.org/web/20000914153406fw_ … om.tw/error.htm
Reply 6 of 6, by holoprox
PC Hoarder Patrol wrote on 2023-12-19, 11:06:
Yes the post codes and Totems point to memory 🙁 but...
50+ flightsticks!
