First post, by xylolfrei
- Newbie
Hello everyone!
I have recently come in to possession of a Pine Technology PT-430 motherboard. It required new capacitors and some trace repair from battery damage but she came back to life.
You can find the retroweb page here:
https://theretroweb.com/motherboards/s/pine-t … chnology-pt-430
It is a very capable motherboard released towards the end of the socket 3 era and supports DX4 processors.
However...
In order to support DX4 chips that run at ~3.3 volts, Pine Tech would sell an optional daughter board containing a voltage regulator that plugged into headers on the board and stepped down the standard 5 volts to 3.3 volts. As you can probably guess, this daughter board is unobtainium at this point.
Therefore, I come to you in the slim hope that someone out there is in possession of this daughter-board and could upload high-res photos of both sides. That way, I could reproduce the board and unlock the true potential of the PT-430. From the photos I can find online, it seems like a relatively simple board but being able to see the traces and values of components would be incredibly helpful.
So far to go but can't turn back though
Cheap tobacco, cup of black Joe
Fueling my body, jump-starting my soul
Set my mind on cruise control
