First post, by Latiodile
- Newbie
Temporary sorta solution found, SATA seems to consistently brick the system, i have to use IDE, and if i want an SSD i'll need a CF/SD to IDE adapter with this particular motherboard
i got it to boot, setup and install all the important drivers using an ancient 40gb IDE hard drive
the SATA/IDE issue is no longer my problem, now my problem is i'm not getting full graphics acceleration, i'm only getting a score of about 2000 in 3dmark 2000, and i get SEVERE input lag in some games, as well as extremely low performance, even at 480p
I recently got myself an MSI K8MM-V for a dedicated windows 98(SE) build and I seem to have had no end to the issues when it comes to drivers, the ones on the MSI website, ESPECIALLY the USB ones seem to consistently brick windows, or cause usb to stop working entirely. i don't have a ps/2 mouse or keyboard, and currently can't get one so i have to work with what i have
this board uses a VIA K8M800 chipset, the drivers i've found for similar ASUS and Gigabyte boards don't seem to help either
i have a sata ssd connected directly to the sata port on the board, the sata controller set to IDE in the bios, if that adds any issues, i can see if i can dig up an old ide hard drive from a scrap pc i have lying around
in the pc properties pane i also get messages about Disk A and C being set to ms-dos compatability mode, as well as compatability mode paging enabled, and since i'm a complete novice to anything of the sorts i have no idea how to solve this. i don't even have a floppy drive installed and i have the controller disabled in the bios so i have no idea why there even is a drive A
anyone got any ideas as to why usb, drivers, and for some reason the "standard dual pci ide controller" seem to absolutely destroy windows whenever i try to install the driver?
edit: forgot to mention, in case this is important information, i'm running the 1.9 bios for this motherboard. in case anyone has any idea
sorry if this is in the wrong category i just signed up and only got the gist of where to put this from a brief search, every post mentioning this chipset is for at minimum XP
