First post, by informatyk
- Newbie
Hello, I've got motherboard DFI CA64-TC https://theretroweb.com/motherboards/s/dfi-ca64-tc which does not beep on startup and does not boot. I tried with and without RAM, GPU but still the same, after powering on switch fans keeps running at 100%. FSB was set to AUTO. I cleard the CMOS. It should at least beep right? How to check if it is dead?
