First post, by Sphere478
Competition rules:
-Must complete at least three passes 3dm2000, or one hour of super pi, no time evidence required, honor system. But do post screenshot of score alongside cpu-z showing clock freq.
-Modded 2+ is allowed.
-Any fsb
-Any mobo
-Any ram
-Any video
-Any sound
-Any OS
-No sub ambient cooling methods. Water cooling is allowed, but no phase change or thermocouple/tec/peltier cooling. If your environment is below 60f please make note of it in post.
This is a core clock competition not a score competition.
Sphere's PCB projects.
Reply 3 of 10, by PC@LIVE
I'm currently working on some S.7's, trying to fix some issues, I have a Soyo 5BT5, which has a missing cache chip pin, until I fix that I can't use the L2 cache.
The alternative would be to use, a CPU with integrated L2 cache, for example I would have a K6-2+ 400 1.6V, which could be installed, but the minimum jumper voltage is 2.2V.
These could be undocumented settings, which could give different voltages (from those reported in the manual), and could be found by measuring the voltage without the CPU.
In the image there is how to do it, personally I have never tried it, but it is possible that it works on any S.7 motherboard.
If I could get 2.0V or less, I could use the K6-2+ with FSB 66 or 75, and multi 6X, getting 400 or 450 MHz, I hope it works, but if there are problems, perhaps the BIOS would need to be modified to support that K6+ processor.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
Reply 4 of 10, by debs3759
Sphere478 wrote on 2024-01-21, 18:46:
Competition rules:
Surely super pi is the better test, as it's more CPU intensive?
Reply 5 of 10, by Sphere478
debs3759 wrote on 2024-01-22, 03:22:
Competition rules:
Sounds plausible.was figuring some around here might already have the 3dm2000 work done and could just post without much fuss. Tryin to accommodate. Basically, if they are sure it’s stable. Post it up!
Reply 6 of 10, by Jasin Natael
Mine is currently clocked at 616mhz @ 112x5.5.
I'll have to fire it up and run the marks to see how stable it is. I can't recall the voltage, maybe 2.3v?
I will try to do some testing this week just to see, I have a feeling it won't be 100% stable and will only be at 6x100.
Reply 7 of 10, by Sphere478
Jasin Natael wrote on 2024-01-24, 17:20:
I recently seem to have discovered the source of my instability system bios cashable was turned on. Reminder to turn that off on k6-+
Kept having crashes at specific spots when installing linsux and random windows crashes. It seems it is stable 112x5.5 now!
Reply 8 of 10, by Repo Man11
Over many tests this was the highest speed my combination was able to achieve. I've seen people go higher than this, but after trying a number of both genuine K6-3+ chips and cache modified K6-2+ 570s, I've never been able to reliably go higher than this. I even recapped the board, but nope.
Reply 9 of 10, by Sphere478
Wow.
Damn, I really need to get my TI500s working… I even have a Hercules purple one.. but can’t seem to get it to post and the gainward one doesn’t seem to want to work with the drivers.
Btw, I also am at 112x5.5
There were some guys around here binning k6-3+570 chips a while back (modded) and installing athalon heat spreaders on them with liquid metal. Would be cool to see what one of them came up with for a record.
Reply 10 of 10, by Jasin Natael
Sphere478 wrote on 2024-01-24, 23:30:
Good to know, thank you. I will have to check that.
