W98-XP Best Forceware drivers
First post, by tony359
Hi all,
I'm doing this project where I am upgrading my Retro PC - everything went wrong, everything failed plus the usual Windows quirkiness. But I am finally at a stage where things seem to work.
Over the project I purchased an Geforce 2 MX400 and a Geforce FX5200 (I thought the MX400 was faulty).
I'm currently using the FX5200 (Shuttle 591P, MVP3, 128MB, K6-2 500MHZ, W98SE) but I am told that the MX400 might be faster than the FX5200 under W98SE.
Happy to try but I see that the driver version plays a big role on those old systems. On my XP built, the latest Forceware was producing awful results under UT99 - something like 0.25FPS!
I understand that "the latest" is not necessarily the best when it comes to video cards back then. Is there a general consensus of what would be the best nVidia driver for
MX4000 under W98SE and XP
FX5200 under W98SE and XP
Thank you!
My Youtube channel: https://www.youtube.com/@tony359
Reply 1 of 23, by ciornyi
Well k6 500mhz might be a reason of bad performance .
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3_900/256mb/SB live/3dfx V3
Win Me: Athlon 1700+/512mb/Audigy2/Geforce 3Ti200
Win XP: E8600/4096mb/SB X-fi/HD6850
Reply 2 of 23, by revolstar
tony359 wrote on 2024-01-22, 12:14:
Dunno about Win XP, but Detonator/FW Driver v45.23 (http://vogonsdrivers.com/getfile.php?fileid=1408&menustate=0) is usually recommended for Win98 when it comes to the FX5200.
Win98 rig: Athlon XP 2500+/512MB RAM/Gigabyte GA-7VT600/SB Live!/GF FX5700/Voodoo2 12MB
WinXP rig: HP RP5800 - Pentium G850/2GB RAM/GF GT530 1GB
Amiga: A600/2MB RAM
PS3: Slim model, 500GB HDD, mostly for RetroArch, PSX & PS2 games
Reply 3 of 23, by tony359
ciornyi wrote on 2024-01-22, 14:09:
No, "downgrading" to an earlier release makes UT99 playable. 0.25FPS (one frame every 4 seconds) wasn't an exaggeration. Clearly a driver issue.
Thanks @Detonator, that's really helpful. I think it's what I ended up using with the MX400 as well under XP as the latest were causing that issue with UT99.
Reply 4 of 23, by PcBytes
Can confirm, and add that this usually worked well for me. 45.23 seems to work universally across many cards from the pre-GF6 era.
MX4000 - 45.23 for 9x, 71.84 for 2k and I suppose XP works as well
FX5200 - same for 9x, 93.71 for 2k/XP
Reply 5 of 23, by tony359
Interesting. Thank you!
The drivers which failed to work with XP and UT99 were 93.71. I went back to 45.23 and it worked ok.
3DMark2000 worked fine with 93.71 though. How bizarre.
Reply 6 of 23, by danieljm
In general the older drivers are faster (less CPU processing overhead). And since an FX5200 will need much newer drivers, it will almost certainly perform worse on a weaker CPU like that. As an example, on my P3-500 system I found almost no difference between my GF2 Pro and GF4 Ti 4200 because of the need for newer drivers. So I just stuck with the GF2 Pro for that system.
Anyway, I can't speak to XP, but I just so happened to do a few tests of drivers with an MVP3 board and a GF2 MX 400 a while back. My best result was using driver version 8.05. But I found that the VIA chipset drivers could cause problems. Choosing Turbo AGP would cause graphics corruption, but Standard worked fine, and that was my best result overall.
Hopefully that's helpful. And keep up the good work on the videos, I really enjoy them.
Reply 7 of 23, by RandomStranger
danieljm wrote on 2024-01-23, 06:45:
The Ti4200 is already CPU limited on a twice as fast CPU. I don't doubt the driver overhead reduced the performance even further, but your system was never balanced in a way where the performance difference between the GF2 Pro and the Ti4200 can come out.
Reply 8 of 23, by tony359
Thank you both
Yes, I am aware you don't want Turbo AGP on an MVP3, the AGP implementation is flaky. I also found I need AGP aperture at 8MB - could be a coincidence though, but I think I'm happy to leave that where it is, this project has taken WEEKS! 😀
I never thought the issue here could be the CPU. Good point. I thought it was more a driver issue. Fair enough, it makes sense to have the FX5200 on my Pentium 4 then 😀
Why would newer driver require more CPU to work?
I think I am on 7.76 on Windows 98 at the moment. I can try 8.05 as well. And I will test the FX5200 with 45.23
Thank you, wish me luck 😁
Reply 9 of 23, by tony359
Update.
It's true, both MX400 and FX5200 performs identically under 3Dmark2001. Same score. I used 7.76 for the MX400 and 45.23 for the FX5200.
This is a K6-2 500 with 128MB PC100, 2-2-2, interleaved. I guess the 5200 will go to the P4, it's wasted on the socket 7 😀
Reply 10 of 23, by RandomStranger
tony359 wrote on 2024-01-23, 21:32:
Update.
No. It's just that slow. Well, to be precise, I'd expect i to outperform an MX400, it's roughly on the level of the MX440/460. Unless it's a 64bit FX5200 with slow RAM. Then it can legit get as slow as an MX400.
Either way, it's slow for a P4.
Reply 12 of 23, by Takedasun
Best graphics card for AMD K6-2 350 Mhz processor.
Best performance in D3D for K6-2 system - RivaTNT2 (driver v2.xx), OpenGL - Geforce 2/3.
Reply 14 of 23, by Takedasun
tony359 wrote on 2024-01-24, 14:50:
wow that's a test!
Too bad the 5200 is not there.
How do I check whether my FX5200 is 128bit or 64bit?
GF FX5200 and FX5500 it's practically the same thing. (250/400Mhz vs 270/400Mhz)
You can check it in RivaTuner and aida64
Reply 15 of 23, by RandomStranger
wow that's a test!
HWiNFO
The FX5200 can come in many flavours. Any combination of 64/128bit and 133(266)/166(333)/200(400)MHz RAM. Unless it's a 128bit 400MHz model, it won't consistently beat the Geforce MX models. Most common are the 64bit 400MHz models.
Reply 16 of 23, by tony359
It's a 64bit unfortunately, 166(333)MHz clock
The MX400 runs FASTER on my P4, 3DMARK 4398 of the MX400 vs 4139 of the FX5200.
Unexpected! 😀
The 5200 though supports more stuff than the MX400? What would you use on your P4?
Reply 17 of 23, by Takedasun
They are both weak for P4.
73.68 KiB
If you choose between these two, the FX5200
Reply 19 of 23, by RandomStranger
tony359 wrote on 2024-01-24, 17:40:
It's a 64bit unfortunately, 166(333)MHz clock […]
Unexpected! 😀
With those specs it's not unexpected at all. The FX has half the bandwidth compared to the MX400. That 5200 is only good for testing uncertain hardware or experimenting with overclocks and BIOS flashing.
