First post, by Shponglefan
- l33t
Updated 02/26/2024:
SSD issues have been solved. Solution was to set the PIO Mode to 3 in the BIOS. Proceeding with installs of various operating systems.
Updated 02/24/2024:
Started trying to set up quad boot system with BootIt Bare Metal. Have run into issues with the Windows 95 and 98 SE setup programs failing due to "General failure reading drive C" errors.
Details in this post: Re: Quad boot with a Pentium 4 2.8 GHz (DOS / Win 95 / Win 98SE / Win XP)
Original post:
I'm planning a multi-boot system with four operating systems: DOS 6.22, Windows 95, Windows 98SE, and Windows XP.
Partitions are planned as follows:
Changed plans and went with multiple drives for each OS.
C: - 2GB FAT16 - DOS 6.22
C: - 32GB FAT32 - Windows 95
C: - 128GB FAT32 - Windows 98 SE
C: - 500GBNTFS - Windows XP
The idea is to have each OS on its own dedicated primary partition.
Based on some primarily research my primary requirements are:
1) Plain text boot menu (e.g. no Plop, GAG, etc.)
2) Auto partition hiding
I've looked into OSL2000, Smart Boot Manager and Boot-Us as potential options. I know OSL2000 and Boot-Us require paid licenses; not sure if it's still possible to buy a license for those?
Any other suggestions are welcome.
Second question is order of OS install. Is there any preferred order of installing these operating systems or if I am booting directly into each partition individually, does it even matter?
