First post, by uniracers
I am trying to get a Compact Flash IDE interface working on my Dell 316SX. I first tried with a 512 MB CF card. Was able to use fdisk to create the partition, and then format the CF card and copy the system files. After doing this, I was able to use "dir" to display the directory of files on the CF card. However, attempting to run command.com for example from the CF card resulted in a "Not ready reading drive c" error. Thinking maybe the size of the CF card was an issue, I also tried a 256 MB CF card, but got the same result. I also tried a different CF IDE interface, but again was not able to run anything from the CF card.
The cards I am using just say "Extreme CompactFlash Industrial UDMA". I tried the first CF card adapter (which is the kind that plugs directly into the IDE port) with the 512 MB on my Athlon XP computer, and it seemed to work fine. I was even able to boot from the CF card.
Does anyone have any suggestions on what to try? I know I could try another CF card, but I don't want to spend money blindly trying to find one that works.
