First post, by Maryoo
- Newbie
Socket 370. I am looking for a microATX board with P III 900 FSB 100 support.
Better pic? Guessing vt693 + vt 596A.
The board is some ultra cheap brand, not screaming quality.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Better pic needed, but it looks a lot like a Vtech/PCPartner design (with that 'Super' on the PCB). Pretty generic low-end ApolloPro+ model.
What do you want to know about the board? Perhaps (with a good pic) we might be able to answer that without knowing exact model.
If you want P3-900E support you need FC-PGA. Given this board's age, it's almost certainly PPGA only, so max Celeron Mendocino 533.
Layout looks like this one: https://theretroweb.com/motherboards/s/pcpart … 892s-35-8848-xx but without the audio bits.
