Also what is gonna make a difference is where on the board your RTC is, if it is up between the first PCI/ISA slot and the CPU, even with airflow it's not gonna cope too well with the swings. If it's down on bottom right of board, where the speaker and front panel connectors usually are, that's a relatively cooler = less swing spot.
Back in the day before ubiquitous internet connectivity and NTP correction of the clock frequently, there were numerous ways to get time corrected, or continuous "right time" some appliances also used them. There were time signals in some FM broadcasts that can keep radio alarms honest, there used to be some in PBS TV broadcasts that some VCRs set themselves by (A royal PITA post digital transition because many of them never had a manual timeset option). In europe there were teletext services going out over broadcast, and it was more simple to grab the timesignal out of those than fully decode the text so there was a couple of computer cards that just did that.... Then there were weather service and navigational broadcasts on VHF channels that had a time signal. Then there was/still is the atomic clock time signals which go out on a low frequency broadcast. Later in the 90s GPS dongles just started getting attention as a time source. There were multiple small production boards for catching time signals from these sources for various commercial/scientific needs. Some projects in the likes of Elektor and Electronics Today etc as well.
Edit: Maplin in the UK used to do an atomic clock receiver that connected to a serial port. UniversalSolder.ca is a modern source for atomic clock receivers but not sure if any of theirs connect to a PC like the Maplin one would, but it's probably do-able.
EditII: Heh, or you can get your very own atomic clock not just a receiver of the signal from elsewhere https://shop.stepglobal.com/XHTF1021/Compact- … dash_232/pd.php
