First post, by Half-Saint
I obtained this board several years ago and only now got to playing with it again. The problem is, I don't see any memory increase when I type mem. How do I get this card to work? Does it need special drivers?
Reply 1 of 3, by dionb
Offtopic: that board has one of the worst possible names for googling info...
Those banks of dipswitches need setting to put the memory in the card at the right addresses for your system, and indeed in the right mode (convetional, EMS or XMS). Those settings are completely specific to the card, so you need the manual for this card to figure it out - unless there are switch settings on the back of PCB 😉
Not had any luck locating info on the board yet (see the offtopic).
