First post, by DarthSun
The record so far: 6926 - https://hwbot.org/submission/4960036_ptr1ck_3 … doo2_6926_marks
I surpassed a definite advantage.
435.44 KiB
289.45 KiB
480.33 KiB
419.96 KiB
Reply 3 of 6, by DarthSun
ptr1ck wrote on 2024-04-01, 12:37:
Congrats!
I no longer have that system together, but may mess with it again one day.
Thanks ! You have a serious result, it was not easy to get over. I'll even experiment with other configurations.
Reply 4 of 6, by ptr1ck
I wasn't going for a record at the time, just happened to get a really good score. Nothing was out of spec or unstable. It was a fully built system in a case with all peripherals.
I have some good Voodoo 2s that I'm not sure of branding but have 110ns memory modules on there. The limitations of the system was the motherboard doesn't support 12v for CPUs and couldn't get my Athlon much higher. Also, I wanted to go with more of an all in one build that can stretch it's legs a little further back in time.
A lot of the components, including the Voodoos, are in my KT133 system now.
"ITXBOX" SFF-Win11
KT133A-NV28-V2 SLI-DOS/WinME
Reply 5 of 6, by DarthSun
Regardless, your test was excellent! I have a few more potential configurations, eg Gigabyte motherboard+P4EE proc. And even with me +5pcs Voodoo2 cards, I'll test it ... I'm standing on it now.
-KT133 may also bring a high point.
Reply 6 of 6, by DarthSun
3dm2k/v2sli tip is also added.
Hungary now holds a peak with the legendary V2SLI in 2 categories.
415.55 KiB
HWBOT link : https://hwbot.org/submission/5527660_darthsun … doo2_3175_marks
