First post, by Shadzilla
- Member
Does anyone have any suggestions for a replacement fan for a pair of Coolermaster Slot A coolers? I have two heatsinks and one fan, and that fan is pretty dead. It's a 3 pin Delta AFB0512HB which runs at 6300 RPM and pushes 18 CFM:
https://www.delta-fan.com/products/afb0512hb-af00.html
I've found various 50x50x10 fans but they're all a bit weedy, and I'm concerned that being a CPU cooler it should really have a bit more of a beefy fan, like the original. Noctua don't make any 50mm fans, but I've looked at a 50-60mm adapter and one of their 50x50x25 fans and come to the conclusion that it's almost certainly going to foul on something on the board.
