First post, by Kouwes
- Member
I swapped the AMD K6-2 400 for a 533.
The system:
Soltek SL55-F5, 384MB, Voodoo 3 2000, Aztech sound. The manual says the fastest CPU would be a 500 but I set the DIP switches to a 550, which works since the systems recognizes a 550 cpu at boot up.
All good I thought….yeah right.
In Win98, I got a New hardware detected (monitor). I never swapped the monitor though.
Then the desktop was set at 640x480 and that’s the only setting possible. No way to set another resolution.
The 3dfx drivers are installed and seem to work fine.
Another strange thing: if I set the voltage switches for a k6-2 500 according to the manual the cou runs at 2.4V. 🤔 I changed it to 2.2V but that doesn’t change anything for the screen resolution.
I haven‘t tried swapping back to the 400 CPU yet, but will do that if all else fails.
Edit:
Swapped the 533 for the 400. At first start in Win98 I could change the resolution to 1024 x 786 but after reboot it was still stuck at 640 x 480.
