First post, by fsinan
Hi there,
My TL688-2 is on the way and I dont know how to test SRAMs with it. Is there a procedure or source to look?
Thanks in advance.
System:1
Cyrix 5x86-100GP
U-Board ST1A with "0"KB Cache 😀
System:2
AMD K6-2-475(Changing frequently with Cyrix 6x86MX PR-233)
TMC MI5VP4
System:3
UMC U5S-40
486UL-P101
Reply 1 of 13, by majestyk
It´s self explaining in the software menue.
Be aware, that only totally defective / blown chips will be detected. The TL688 does not test SRAM chips under real life conditions when it comes to frequency and timings. Many chips that test "o.k.", will not work on a mainboard.
Reply 2 of 13, by PD2JK
True, I tested some chips using the SRAM test which turns out OK, but didn't work at all in the board. Some ISSI chips, maybe fakes. Threw them away.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Orion 700 | TB 1000 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 3 of 13, by fsinan
PD2JK wrote on 2024-04-14, 16:03:
Probably not fake but can not work at that specified speed.
System:1
Cyrix 5x86-100GP
System:2
TMC MI5VP4
System:3
UMC U5S-40
486UL-P101
Reply 4 of 13, by CoffeeOne
fsinan wrote on 2024-04-14, 14:45:
Hi there,
Thanks in advance.
What is a TL688-2?
Reply 5 of 13, by PD2JK
Should be TL866II (Plus) I guess.👍
Reply 6 of 13, by fsinan
PD2JK wrote on 2024-04-15, 19:48:
Yes it is.
System:1
Cyrix 5x86-100GP
System:2
TMC MI5VP4
System:3
UMC U5S-40
486UL-P101
Reply 8 of 13, by fsinan
Sadly I couldnt find SRAM ISSI IS61C1024 in the list...How will I test it?
System:1
Cyrix 5x86-100GP
System:2
TMC MI5VP4
System:3
UMC U5S-40
486UL-P101
Reply 9 of 13, by Minutemanqvs
fsinan wrote on 2024-04-20, 17:50:
Bought the same, probably from the same eBay seller than you and…they are absolutely remarked. They were recognised by the mainboard but don’t keep up the speed needed on my mainboard.
In the software, they can be tested using the smaller size SRAM from the same type, it seems to work.
Searching a Nexgen Nx586 with FPU, PM me if you have one. I have some Athlon MP systems and cookies.
Reply 10 of 13, by CoffeeOne
Either "Standard SRAM" and then 628128
or Winbond W24010
Reply 11 of 13, by fsinan
CoffeeOne wrote on 2024-04-20, 19:03:
or Winbond W24010
Thank you found out that last night.
System:1
Cyrix 5x86-100GP
System:2
TMC MI5VP4
System:3
UMC U5S-40
486UL-P101
Reply 12 of 13, by CoffeeOne
fsinan wrote on 2024-04-21, 07:49:
or Winbond W24010
Is there some output of your test?
Reply 13 of 13, by fsinan
CoffeeOne wrote on 2024-04-22, 17:09:
or Winbond W24010
All newly purchased srams are tested ok. But not working on ST1A board.
Took some other cache chips working on other board, again, not working on ST1A. Opened a new message to get some help.
System:1
Cyrix 5x86-100GP
System:2
TMC MI5VP4
System:3
UMC U5S-40
486UL-P101
