Reply 40 of 82, by kolderman
Anders- wrote on 2021-10-13, 21:10:One more important point, it was around that time the floppy port disappeared from the mainboards! My amd64x2 (socket 939), came […]
kolderman wrote on 2021-10-13, 19:21:I remember the Athlonx 64 X2 peaked around the mid-late 2000s, because upgrading meant going from socket-939 (AGP,DDR,IDE,WinXP) to the AM-socket platform (DD2/3, PCIe,SATA,Vista) meaning you needed to upgrade EVERYTHING. It was the last hurrah of 90s era tech and a lot of people wanted to keep that platform running as long as possible, and the Athlonx 64 X2 meant not only could you upgrade to a high clocked CPU, but often it meant upgrading from single to dual core for owners of the earlier single-core Athlon64s, which made a tremendous difference. Was probably the best CPU upgrade in history and no wonder prices went through the roof.
My amd64x2 (socket 939), came with floppy controller, ddr2, sata and pcie+pci 😀Edit: I realize there's a bit of contradiction there, will have to doublecheck next time I got the case open.
Pretty sure I've seen both "939" printed on the socket as well as buying 4x1G ddr2 back in the day...
There was a lot of weird stuff around this era, like boards with both AGP and PCIe, possibly DDR1/2, but I have mainly seen DDR2/3 on latter gen boards like s775.
