First post, by wbahnassi
Hi. Got an unfortunate surprise on my main DOS PC case today. Brown circular markings became imprinted on the top of the case where the rubber feet of a network switch used to rest.
Any idea how to fix this (short of repainting)?
1.45 MiB
1.05 MiB
1.53 MiB
Reply 1 of 15, by Sphere478
Try scrubbing it with goof off?🤔 I think the paint would survive goof off, may wanna try a small area that isn’t visible first though
Sphere's PCB projects.
Reply 3 of 15, by BitWrangler
WD40 lifts tarry stuff, but I'd spray some on a rag and rub at them.
Reply 4 of 15, by wbahnassi
Tried 99% IPA.. the browning got off very very slightly after rubbing rather strongly for several seconds. The tissue came out with gray material on it, so I'm afraid it's starting to take off the case paint.
No obvious discoloration yet, but I'm not continuing with the IPA.. I'll see if WD40 makes any better results.
Reply 7 of 15, by Sphere478
You can try UV it can bleach some dyes white over time. But I doubt it will work. Probably turn your plastic yellow.
Reply 8 of 15, by BitWrangler
I think if it was on the surface of the paint one of the things tried should have lifted it. It sounds like it has absorbed into the paint. If the paint is plenty thick and it's just barely into the surface, then cutting back the paint with a metal polish might work, or you could try a whitening toothpaste I guess if you've got that around. On a cotton cloth for either of those, paper towels etc will just disintegrate before much happens.
Reply 9 of 15, by Sphere478
BitWrangler wrote on 2021-12-30, 05:31:
comit, barkerpers friend, baking soda. Will work similar to toothpaste but more agressive
Reply 11 of 15, by 1541
Sounds kind of silly, but you could try the blue side of a regular rubber to rub off the remains of the brownish rubber feet:
9.2 KiB
💾 Windows 9x resources (drivers, tools, NUSB,...) 💾
Reply 12 of 15, by Sphere478
1541 wrote on 2021-12-30, 09:06:
Those work good cleaning old cpus. This is a good idea. Might work here also.
Reply 13 of 15, by wbahnassi
Tried Magic Eraser, baking soda, and even dishwasher powder detergent. None worked 😐 This thing is really baked in there.. dang.
I don't have any of those red/blue erasers around to try, but I'm becoming quite skeptical at this point.
Still, thanks all for the suggestions so far.. I'm starting to imagine Khaby Lame suggesting something obvious instead of all this. Maybe just cover it up with some decorative cloth and call it a day? 😅
Reply 14 of 15, by Sphere478
Try UV prob won’t work but what the heck,
Reply 15 of 15, by ratfink
Label remover (contains limonene I think) will shift some things. Otherwise I would scrub with a kitchen/bathroom surface cleaner of some kind, though that's likely to work best if it contains some scouring component which may ruin the paint finish slightly.
Alternatively of course, put the network switch back where it was (!) or something similar like a KVM switch or a box of CDs, or cover it with a cloth. When I used to stack my PCs 2-high, I put cut-up cleaning cloths under the feet of the top ones. Probably I had had the same issue as you (long time ago) or was just paranoid about scratching things, but decaying rubber is a big annoyance in so many areas. Recently I found that the matt rubber finish on my best ps/2 keyboard had gone sticky (think it's cleaned up ok with diluted spray disinfectant), as well as a camera lens (likewise some manufacturers give their camera bodies this surface treatment); old film camera light seals decay too, and there is needless internal foam rubber padding in all kinds of things (an old IBM typewriter I obtained was full of foam that turned into sticky black mush when touched for example - presumably for sound muffling despite it being noisy as hell anyway). End of rant 😉
