PCI Modem Cards
First post, by twiz11
What do you do with PCI Modem Cards these days? I was thinking of internet faxing or old-school VOIP. Most of the time I gut them for screws whenever I find any. There are adapters to convert rj11 to rj45 but I don't think that would work for in-line house phone jacks. Gah I am glad I ripped out the old phone lines. This is just a pet project to see how the heck do you convert ethernet to dialup and vice versa just for the hell of it.
RETIRED
This user is no longer active on VOGONS.
Reply 1 of 7, by Grzyb
I do with them absolutely nothing...
...though once upon a time, I had an idea to use such a card in a troll build, as the only connection 🤣
Reply 2 of 7, by Joseph_Joestar
I use them for (de)soldering practice. 😁 Well, at least the broken ones.
One or two of my old PCI 56k modems might still be functional, but I have no use for them nowadays. I hated those flimsy things with a passion back in the day, and had them packed away the second I got faster internet.
Reply 3 of 7, by swaaye
I don't think I ever personally had a PCI modem. Other than one integrated in a notebook. I had external and ISA modems though.
At work I still have a FAX modem in use in a Laserjet all in one. They still come integrated in various printers. They can have problems with modern internet based phone lines though. I had to disable its error checking and v.34 speeds.
Reply 4 of 7, by lti
I ran out of expansion slot covers, so I put a modem in that slot to fill the hole in the back of the case. I think it still works (since Windows detected it and installed the drivers), but I haven't had a use for it.
Reply 5 of 7, by leileilol
you bridge dreamcasts with them
Reply 6 of 7, by doshea
I think I heard or read that some of these cards could potentially be used by Asterisk, so one could built their own PABX - and hence have something that old phones and modems could connect to - but I'm not sure if I ever found any information about what cards are supported, if any.
lti wrote on 2023-04-22, 21:00:
Not enough slot covers is always a problem! You could probably unscrew the bracket from the card and just use the bracket 😁
Reply 7 of 7, by Tetrium
I never used any modem cards in any of my builds, though I did consider it especially for the odd AMR/CNR/ACR slotted ones (not sure I even have any boards for all of these slots). But the main issue for me is how useless the are. The dialup tone would be kinda nice to hear again I guess.
My retro rigs (old topic)
Report spammers here!
