First post, by rfnagel
- Oldbie
Just a few rather miscellaneous Windows XP snippets that I've either copy 'n' pasted, edited, and/or typed up through the past year. The latest being the "Sound Blaster Live! DevLdr32.exe Removal".
I recently upgraded the Micro$not Internet Exploder to version 8 (so's I could blather on Facebook, they didn't support my old MSIE6 anymore <grin>), and then ran into a problem where clicking on any link within a Windows "CHM" format help file resulted in a script error <aarrgh>!
I decided to take the plunge and install Service Pack 3, but discovered two problems:
Although SP3 fixed the script errors, I saw numerous error messages within Windows XP's "Event View" (Event ID: 1904, in Source: HHCTRL).
and...
was having shutdown problems with this "mysterious" file "DevLdr32.exe". Read tons of stuff on the Internet about it, NONE of which was of any use. I was hesitant about messing with it, as I thought that it was used for my Sound Blaster Live!, but in actuality it's not needed under Windows XP SP2+ with the latest SBLive! drivers (from Creative Labs' site) installed.
Spent the past two damn days sorting this one out <aarrgghh>!
Anyhoo, here's what's in the attached ZIP... maybe it'll prove useful for one or two folks 😀
Decompiling Windows CHM Help Files.txt
How to decompile Windows CHM help Files to HTML.
Disabling Compress Old Files.txt
How to disable "Compress Old Files" in Windows Disk Cleanup (massively speeds up Disk Cleanup's startup).
Enable Compress Old Files.reg
Undo the "Disabling Compress Old Files" above (re-enables "Compress Old Files").
Disabling Local Machine Lockdown.txt
Disables "Local Machine Lockdown" that was introduced by Windows XP Service Pack 2. Local Machine Lockdown will cause Internet Explorer's "Information Bar" to be displayed for any local HTML files on your hard drive (or CD-ROM) that contain Java, Javascript, or Shockwave Flash objects.
Foreground FlashCount and LockTimeout.txt
How to adjust Windows XP's "Foreground FlashCount" (number of times that Windows XP will flash a background application's taskbar button when the application wishes to steal the focus from a foreground application), and "LockTimeout" (time in milliseconds before Windows XP allows an application to steal the focus from a foreground application).
HHCTRL Event ID 1904 Error Fix.txt
HHCTRL Event ID 1904 Error Fix.reg
Fixes a problem where clicking on links within Windows "CHM" format help files generates numerous error messages that can be seen within Windows XP's "Event View" (Event ID: 1904, in Source: HHCTRL).
Hibernate.txt
Restoring the "Hibernate" button in Windows XP (Note: requires Windows XP with Service Pack 3 installed).
Sending Commands Directly to a USB Printer.txt
Printing and sending commands directly to a USB Printer under Windows XP (Note: I haven't thoroughly tested this one).
Slipstream Windows XP Service Pack 3.htm
How to "slipstream" Windows XP Service Pack 3 to create an integrated Windows XP installation CD-ROM with Service Pack 3 (Note: instructions by Christopher Heng).
Sound Blaster Live! DevLdr32.exe Removal.txt
Removing/disabling "DevLdr32.exe" and "DevCon32.dll", which were older driver files for Windows XP legacy sound support for the Sound Blaster Live!, and were included with the Windows XP installation CD-ROM. They are *NOT* required by Windows XP with a Sound Blaster Live!, and with the latest Creative Labs Windows XP drivers installed (English LiveDrvUni Pack: "LiveDrvUni-Pack(ENG).exe", February 28, 2003).
System Volume Information.txt
Accessing the locked "System Volume Information" folder in Windows XP (a.k.a. It's *MY* hard drive, dammit!).
Windows XP ChkDsk Logs.txt
How to view Windows XP "Check Disk" Logs.
Windows XP Recovery Console.txt
How to installing the Windows XP recovery console (before or after Service Packs have been installed).
P.S. Not in the attached ZIP...
Man! That MSIE8 is an abortion! I swear if Bill Gates had his way, the ENTIRE freakin' screen would be filled with non-moveable toolbars, taskbars, menus, icons, and other such crapola! By the time he gets done with it, the only thing you'll be able to see in your browser is two or three lines of text!
That infernal gold "Favorites" star is severely annoying. The only way to can it is via a registry hack, but the con of that is it ALSO removes the entire "Command" bar <aarrgghh>.
I then "discovered" that you can hide the usual "File" menu, and *even* if it's hidden, you can still press "ALT" on your keyboard and it will magically appear 😀 See attached pic... nice and small band at the top, with plenty of real estate for web browsing 😀 Heh, of course, nothing beats good old "F11" though <grin> 😀
I swear, if BG had his way, we would all be walking around with "File/Edit/View/Help" tattooed to our foreheads!
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
