Reply 40 of 44, by ProfessorProfessorson
- Member
I don't really have any complaints in regards to any of the sdram based Socket 370 boards I have messed with, other then the Trigem Cognacs. And in regards to them its only a small gripe concerning disabling onboard audio and using pci audio cards, and the fact the boards dont have agp support. Thankfully the onboard audio on them isn't terrible, so you can get by using it if you find the one you got doesn't like your pci audio card, and I have not run into any problems running any given pci video card on them.
