First post, by Gemini000
Some people are more comfortable with hardware, some people are more comfortable with software, I thought it would be neat to see everyone's thoughts on this.
So which are YOU most comfortable with?
For me, I'm definitely a software person. I CAN do hardware work if I have to, but if problems occur then I often get stumped for a moment trying to figure out how to solve it, plus I always feel like I'm gonna electroshock something (even though I never have).
Whereas when it comes to software, having been programming since early 1993 when I was 10 years old, I can get virtually any old program running if I absolutely have to and I've even had success with hacking things, such as adding 1280x1024 resolution support into the PC version of Wipeout XL. ;)
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
Reply 1 of 29, by nforce4max
I am a hardware person as I like having my hands on something tangible rather than something that only exists as electrons in a circuit. Hardware is simple and easy to understand while software is made to be over complicated as well bloated.
Reply 2 of 29, by Tetrium
I'm also more a hardware person. Sure, I can handle software somewhat fine (with the help of google 😜 ) and I can find solutions to software problems that way, but hardware is really more my thing 😁
I'd say I'm hardware/software like 65/35 or so 😁
My retro rigs (old topic)
Report spammers here!
Reply 3 of 29, by leileilol
I don't like to solder.
Reply 5 of 29, by cdoublejj
I like to solder and i can't code but, seem to do well software.
Reply 6 of 29, by 133MHz
Definitely hardware, due to my electronics background.
I've done a few things in Borland TurboC++ and Arduino but I don't consider myself a good programmer.
http://133FSB.wordpress.com
Reply 7 of 29, by JayCeeBee64
Rank Retired
Retired
Hardware for sure, I like tinkering with computers parts quite a bit 😁. Software, not so much (if it's simple and and easy, OK. Otherwise, forget it 😒 ).
Ooohh, the pain......
Reply 8 of 29, by RoyBatty
Both, I like hardware and software, collect and play with it all. xD
Reply 9 of 29, by Stojke
Hardware, but im aiming for software as well. And improving my knowledge on hardware a lot as well.
Reply 10 of 29, by eL_PuSHeR
Software here although I tinker with hardware sometimes.
Reply 11 of 29, by m1919
Hardware and software.
Crimson Tide - EVGA 1000P2; ASUS Z10PE-D8 WS; 2x E5-2697 v3 14C 3.8 GHz on all cores (All core hack); 64GB Samsung DDR4-2133 ECC
EVGA 1080 Ti FTW3; EVGA 750 Ti SC; Sound Blaster Z
Reply 12 of 29, by badmojo
Neither do much without the other, so I play with both equally I'd say. I like the problem solving aspect of computers, which is probably why I'm still messing around with 486's 😀
Reply 13 of 29, by Filosofia
Hardware guy, I was performing upgrades since I was 10yo, like Gemini but on the hardware !
The only software I need is: drivers for the sound and graphics in GAMES!
An OS also comes handy sometimes 😉
Reply 14 of 29, by GXL750
Hardware. It's the least stressful. You slap some crap together and it goes. Software is getting closer to being like that. If you're always busy, it's nice to just have a cheap computer, and if it breaks, the next one is just the same. Everything important is in the cloud so no worries.
Reply 15 of 29, by MaxWar
I like to solder, the "pshhht " of flux vaporizing as the fresh solder melts and bonds about is a wonderful thing.
FM sound card comparison on a Grand Scale!!
The Grand OPL3 Comparison Run.
Reply 16 of 29, by cdoublejj
Well definitely tinker with software to an extent trying os and from time to time hacks/mods maybe i'm closer to both?
Reply 17 of 29, by sgt76
Hardware, definitely.
Reply 18 of 29, by Gemini000
Well, the results of this have not been too surprising to me. I kinda felt going into it that I was one of the minority who was more comfortable with software over hardware, which is part of the reason why I started the thread, to see if my thoughts on that were correct.
I also kinda realized that most people who are more comfortable with software over hardware tend to be programmers. I myself started writing code when I was 10 years old, while the very first time I worked on the inside of a computer I was 16. (Swapped a dead CD drive for a new one.)
Reply 19 of 29, by Tetrium
It's not that I don't like software per se, but I'm just not very good at it. I can't code (though I can do some copypaste in existing code) and I mainly use software to get my hardware going.
For instance, I've had fun using a slipstreamed version of XP on some of my rigs and experimenting with that, but that was mainly to get the software to behave more to my liking.
That said, I'm not a hardware guru either, but hardware is definitely where the majority of my interest is.
I use my rigs mainly to play games (except for my primary rig, which I use for the usual day to day stuff).
