First post, by Pingaloka
Hello guys, I've been searching this information but I have not found the answer.
Is it possible to install MS-DOS 6.22 in a 486DX4 with WinAmi Bios from a CD-Rom or CF IDE? I cannot see in the bios any option to change booting devices.
Only options I've found are:
a) booting order, A: C: or C: A:
b) Floppy Drive seek at boot
Reply 1 of 7, by bucket
Your computer can only boot from the floppy or primary HDD. I don't think you need to boot into the install disc, so try downloading a boot floppy from bootdisk.com.
Reply 2 of 7, by Pingaloka
Sorry I didn't understand what you meant bucket. What can I do if I want to format c: and install DOS 6.22?
Reply 3 of 7, by ratfink
Not sure you can boot dos from a cd.
To install dos to a cf card, get an ide adapter to plug the card into your ide port on the motherboard as you first hard drive. Some ide adapters hold 1 cf drive and the drive can be set as master or slave, others can hold 2 cf drives and one will be master and the other slave.
Use the bios to set up the drive geometry if necessary [various threads on here discuss that] - this is not necessary on later boards [at least my socket 7 detected my cf drives fine].
At this point you should have a cf drive set up as as c:.
Use dos floppies to install dos to this c: drive.
Reply 5 of 7, by TheMAN
no 486 I know of can boot from CD-ROM, ZIP drive, or LS-120 drive.... the BIOS is just too old
the only things you can boot are Floppy, HDD, or SCSI device... SCSI depends on having a SCSI BIOS either built into the motherboard (rare) or if the addon card has a BIOS
some SCSI2 cards with BIOS and pretty much anything SCSI3 and newer can boot anything pretty much.... SCSI floppy drives, SCSI optical drives (CD-ROM, DVD-ROM, MO disk, etc)
if you want to boot a CD, you'll need a boot strapper... software solution as said, or use SCSI
Reply 6 of 7, by swaaye
To boot a CDROM on a 486, I used a bootable floppy with a bootstrap called Smart Boot Manager. I'm sure it can be installed onto the hard disk as well.
http://sourceforge.net/projects/btmgr/
Reply 7 of 7, by Pingaloka
Great app, I'll check it out!
