First post, by NitroX infinity
Not quite sure where this should go, so apologies if it's in the wrong place.
Anybody wanna fill me in on how to get my optical drive working in DOS?
I know it has something to do with autoexec.bat and config.sys and adding some lines but that's all I know.
NitroX infinity's 3D Accelerators Arena | Yamaha RPA YGV611 & RPA2 YGV612 Info
Reply 1 of 7, by Kreshna Aryaguna Nurzaman
In CONFIG.SYS:
device=c:\devices\(the name of DOS CD-ROM driver) /d:mscd000
In AUTOEXEC.BAT:
c:\dos\mscdex /d:mscd000 /l:g
The DOS CD-ROM driver can vary depending on vendor, an example is aspicd.sys.
Kreshna Aryaguna Nurzaman.
Reply 3 of 7, by Kreshna Aryaguna Nurzaman
NitroX infinity wrote:
I think I should note, it's a Win98se installation I work with.
Did you try to make the optical drive work in pure DOS, or in Win98's DOS box?
Reply 5 of 7, by Kreshna Aryaguna Nurzaman
Pure DOS; Boot > F8 > MS-DOS
You need to have the correct DOS driver for your CD-ROM and MSCDEX, then edit the CONFIG.SYS and AUTOEXEC.BAT accordingly.
Reply 7 of 7, by NitroX infinity
Never mind, got it working;
I copied cd1.sys from my Win98se boot floppy to C:\Windows\Command\
I put this in Config.sys;
device=C:\WINDOWS\COMMAND\cd1.sys /d:mscd001
And this in autoexec.bat;
C:\WINDOWS\COMMAND\mscdex.exe /d:mscd001 /l:d
Thanks for the help 😀
