First post, by Oldskoolmaniac
Every time windows boots up there is a box that pops up configuring windows, when it goes away desktop refreshes and my wallpaper is gone nothing but a solid background color.
Could it be cause im using a .jpg image Is .bmp recommended?
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 1 of 17, by Jorpho
Why don't you just try it and find out!?
I think JPG wallpapers required IE4 (Active Desktop).
Reply 2 of 17, by Oldskoolmaniac
I did and still same issue and I have IE5.5 installed.
Reply 3 of 17, by mrau
non compressed formats are better for performance;
Reply 4 of 17, by Malik
Disable Active Desktop? (Right click on desktop, and uncheck active desktop / view as webpage)
Reply 5 of 17, by subhuman@xgtx
I think there's an update that causes this glitch. The same happened to me when I had 95c installed on my pentium mmx system.
Bear in mind I usually post to the forums using my old systems.
Reply 6 of 17, by deleted_Rc
iirc there is a 24 real color update for windows 95 included in its PLUS "expansion". save the same image as a 24 bit bitmap and you wont need to use active desktop to display the image. This saves alot of memory and hassle.
Reply 7 of 17, by leileilol
Stock Win95 displayed 24-bit color BMPs fine.
Debian's fucked
Reply 8 of 17, by Oldskoolmaniac
I don't see active desktop anywhere.
I'm using win95c with the unofficial service pack and IE5.5.
When win95 logs in there is box in the corner that says "windows is now setting up the following item" my desktop refreshes then goes to a solid color background.
Reply 9 of 17, by kode54
Have fun reinstalling and installing the IE 4.0 with Active Desktop before installing IE 5/5.5.
Reply 10 of 17, by Jorpho
You should check which items are running at startup, or just check Task Manager to see if there is anything unexpected running.
Reply 11 of 17, by Oldskoolmaniac
Got it working, had to reinstall everything like this Win95->IE4.01->IE5.5->SP1 Now everything is working great! I had no idea IE4.01 would change the whole explore layout.
Had to reinstall windows, i did the exact same same route and now im getting that same problem i cant even change to a solid background.
Reply 12 of 17, by SanguineBrah
Apologies if this is considered unwarranted necro but I think I have some useful information to add. I was having an identical issue to the above, also using OSR 2.5.
After a few reinstalls, I narrowed down the problem to the unofficial service pack. Without it, I am able to set and retain a (bmp) wallpaper but only if active desktop is enabled. I have yet to work out which component of the service pack is causing the problem.
Reply 13 of 17, by shamino
One other thing:
You can use the "Internet Explorer Administration Kit" to make a customized installer for IE5 or IE6 that includes Active Desktop. That way you don't have to install IE4 before the version you really want.
IEAK was a tool for sysadmins that lets you make an installer with customized default settings. One of the checkbox options is to include Active Desktop.
I did it with IE6 (for NT4) a long time ago, but I think the same process can be used on IE5.
Once you've made an installer you can just keep the file and never have to go through the IEAK procedure again.
Reply 14 of 17, by SanguineBrah
IEAK sounds like a handy thing to have around.
One more reinstall and I've solved my problem. This time, I used the lite version of the unofficial service pack instead of the full one. I still don't know which component was responsible but at least it's working as expected now.
Reply 15 of 17, by Oldskoolmaniac
That computer is long gone now, but I do have a win95 era laptop to mess with. Yea its definitely something up with the unofficial service pack. I'm thinking about trying this out https://www.razorback95.com/projects/win95dl/index.php
Reply 16 of 17, by Yoghoo
Oldskoolmaniac wrote on 2021-10-11, 04:25:
Tried to access this site but it's blocked by Bitdefender Antivirus over here. Could be a false positive but be careful.
Reply 17 of 17, by songoffall
Sorry if a necro; on Windows 95 OSR2 I had the same problem, fixed it by removing Browser Web Check and runonce.exe from HKEY_LOCAL_MACHINE\Microsoft\Windows\CurrentVersion\Run.
There's no need to install Active Desktop.
Pentium 2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 2.0GHz/GeForce4 Ti4200/Sound Blaster Live!
Core2Duo Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
