First post, by Errius
 - l33t
Hello all. Someone here once mentioned a data recovery program that would allow you to scan the same damaged CD in several different drives, and would then assemble an image of the disk that would be less corrupt than if you had used just one drive. What was this called? The only thing I've found that sounds like this is IsoPuzzle, but that hasn't been updated in nearly a decade.
https://www.ghacks.net/2008/01/25/recover-scr … ith-iso-puzzle/
Is this too much voodoo?
