First post, by Zup
- Oldbie
Last month my PC blew up. I've changed motherboard, CPU and RAM, and I found that modern motherboards have no PCI slots... so my last soundcard (an Asus Xonar DS) got out of the computer.
Previously, there were some reasons to put a soundcard on your system, like:
- Your motherboard does not include any sound system but the beeper.
- You are a musician and your motherboard has no professional enough sound.
- Your audio output sounds like crap.
- You'd like to use 3D positional sound.
- You'd like to have an onboard MIDI synthetizer.
But today...
- Motherboard often include HDA sound cards (mine got an ALC1220).
- Most people use cheap analog speakers that makes no difference in sound output quality, or buy expensive digital speakers... and I guess that digital output will be exactly the same on a onboard sound chip and in a $600 sound cards.
- Windows deprecated hardware sound acceleration.
- Most soundcards have no hardare MIDI, and MIDI is not used today (and there are software synthetizers that have better instruments than old MIDI soundcards).
So (excluding musicians)... does a regular user have any reason to buy a sound card?
