noshutdown wrote:what does this limit imply? does it mean i can write 60300 bytes of source code(about 1000+ lines i think), or that the translated binary instructions at 60300 bytes long, or i can store 60300 bytes of data?
It's for the tokenized binary representation of your code, plus data. There are things like (IIRC) string space and communication buffers that can be adjusted from the command line if you check the manual.
As mentioned above, you only get a single segment. You can always (ab)use DEF SEG to save/load data in other segments, but that's probably not a good idea unless you know what you're doing.
64K might look limited, but most other machines which ran old-school MS BASIC dialects tended to have even less RAM free for programs.
