SB 2.0 CT1350 CMS chips dumped
Reply 140 of 470, by fire-phoenix-fire
oh no, my card ist without any revision-number 😵 (at first I thought the B could stand for rev2 😒 )
Reply 141 of 470, by DonutKing
Unfortunately no, I think the most common ones are CT1350B, but the CT1350B cards with no revision number on them definitely don't work with the Lattice GALs.
Reply 142 of 470, by Robin4
Do other gals work on the earlier CT-1350B cards? Or still no solution on those cards?
Reply 143 of 470, by carlostex
Has anyone confirmed that a National Semiconductor GAL works with the Rev. 0 cards?
Reply 144 of 470, by Robin4
I havent tried yet..Because i have enough computers to build here.. Iam almost finished with my pentium II build.
But iam hoping starting soon with my faster win98se machine to play faster games on it.
And i dont have space now for the older systems..
So i dont have programmed chips.
If i know if it will works i will you all let you know.
Reply 145 of 470, by bristlehog
It would be nice to possess some information on NS chips on CT1350B cards with no revision.
What's the price of NS GALs against Lattice anyway?
Reply 146 of 470, by carlostex
The price is a couple of bucks more expensive per chip.
Reply 147 of 470, by carlostex
OK i'm gonna contribute to this too. I just ordered an USB G540 programmer and a couple of NS GAL's. Can someone provide me links to the new and old code so i don't lose any time looking for them?
Reply 148 of 470, by carlostex
Great i order National Semiconductor GAL16V8-25LNC and i end up receiving SGS Thomson GAL16V8S-25QB1. Until i receive the programmer i can't test them.
Reply 149 of 470, by keropi
I hope you get it working carlostex , I have a non-rev SB2 too with spare SA chips, I would love to get it working!
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 150 of 470, by bristlehog
Same here!
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
Reply 151 of 470, by Robin4
Same here!
Reply 152 of 470, by badmojo
Same here!
Reply 153 of 470, by carlostex
Let's see, i don't know how will using different GAL's can affect the experience. I just wish the damn programmer comes fast!
EDIT: I just ordered some National Semiconductor GAL's to make the experience as complete as possible.
I ignored Lattice because we already know these will make FM synthesis stop working.
Reply 154 of 470, by keropi
Personally I don't really think that changing the GAL manufacturer will solve the issues , but I hope you really succeed carlstex!
Last year I donated a "problematic" sb2 to the person that cracked the code but there wasn't much progress since then IIRC...
Reply 155 of 470, by carlostex
Ye Keropi i know it's a long shot but at least we gotta clear the doubts. I know about Chuck(G) i've read that thread so many times now....
Reply 156 of 470, by carlostex
Very close to test this. The USB programmer i ordered is arriving today.
Reply 158 of 470, by carlostex
OK it seems i'm struggling with the programmer. I've selected the proper GAL, but when i load the JED file a menu called "file formation" appears. Here i left everything default, and after it a menu named FUSE MAP appears. I suspect this FUSE MAP thing should have the binary which corresponds to the correct code. Except everything is at 0. IS it supposed to be like this? Shouldn't the 1's and 0's appear in this MENU just as it is in the .JED file?
The results i get is either system does not pass POST or i get into DOS prompt with loads of graphics artifacts.
Reply 159 of 470, by keropi
that fuse map looks like it's the GAL's configuration fuses: like copy protection on/off and various other stuff...
I have no idea about GALs, DonutKing might answer this one...
