Reply 20 of 51, by Jorpho
- l33t++
wrote:Sorry I haven't responded to all the suggestions. I started to get confused again, looking at all the different model numbers an […]
Sorry I haven't responded to all the suggestions. I started to get confused again, looking at all the different model numbers and specs. Then I had major problems with my old system (changed a ScanDisk setting telling it to not check long filenames and it renamed most of the files on my system to their DOS names!) so now I'm using the new one.
A friend recommended an ASUS GT 400;
http://www.newegg.com/Product/Product.aspx?It … #scrollFullInfo
$95 seems like an average price for it, and the reviews are mostly positive.
A couple people mentioned it blanking the screen for a few seconds when it gets hot, which is something I would definitely like to avoid. However many also mention over-clocking it, and I've never really been one to OC. I prefer stability rather than the extra little bit of performance I'll get. Also, many people were running games at high resolutions with all the settings turned up to max, while I'm usually happy playing at 1024x768.
That's a GT 440 , not a 400. Small difference there.
wrote:Being able to turn all the settings to max is nice, but all I really want is for the games to not have major graphical glitches, not to crash and to not lag.
Really now, if you want all these things, then you shouldn't be sticking with a Core 2 Duo.
I can't see why you should spend more than $50-60 at this point (assuming you don't mind waiting for a good sale). Even if you're interested in getting a card that you could feasibly use in whatever your next system might be, by the time you get said system, something feasibly much nicer might be available.
