…Show last 202 lines
61# Possible values: none, normal2x, normal3x, advmame2x, advmame3x, advinterp2x, advinterp3x, hq2x, hq3x, 2xsai, super2xsai, supereagle, tv2x, tv3x, rgb2x, rgb3x, scan2x, scan3x.
62
63frameskip=0
64# aspect=false
65aspect=true
66# scaler=normal2x
67scaler=normal3x
68
69[cpu]
70# core: CPU Core used in emulation. auto will switch to dynamic if available and appropriate.
71# Possible values: auto, dynamic, normal, simple.
72# cputype: CPU Type used in emulation. auto is the fastest choice.
73# Possible values: auto, 386, 386_slow, 486_slow, pentium_slow, 386_prefetch.
74# cycles: Amount of instructions DOSBox tries to emulate each millisecond.
75# Setting this value too high results in sound dropouts and lags.
76# Cycles can be set in 3 ways:
77# 'auto' tries to guess what a game needs.
78# It usually works, but can fail for certain games.
79# 'fixed #number' will set a fixed amount of cycles. This is what you usually need if 'auto' fails.
80# (Example: fixed 4000).
81# 'max' will allocate as much cycles as your computer is able to handle.
82#
83# Possible values: auto, fixed, max.
84# cycleup: Amount of cycles to decrease/increase with keycombo.(CTRL-F11/CTRL-F12)
85# cycledown: Setting it lower than 100 will be a percentage.
86
87core=auto
88cputype=auto
89# cycles=auto
90cycles=max
91cycleup=10
92cycledown=20
93
94[mixer]
95# nosound: Enable silent mode, sound is still emulated though.
96# rate: Mixer sample rate, setting any device's rate higher than this will probably lower their sound quality.
97# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
98# blocksize: Mixer block size, larger blocks might help sound stuttering but sound will also be more lagged.
99# Possible values: 1024, 2048, 4096, 8192, 512, 256.
100# prebuffer: How many milliseconds of data to keep on top of the blocksize.
101
102nosound=false
103rate=44100
104blocksize=1024
105prebuffer=20
106
107[midi]
108# mpu401: Type of MPU-401 to emulate.
109# Possible values: intelligent, uart, none.
110# mididevice: Device that will receive the MIDI data from MPU-401.
111# Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.
112# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use.
113# See the README/Manual for more details.
114
115mpu401=intelligent
116mididevice=default
117midiconfig=
118
119[sblaster]
120# sbtype: Type of Soundblaster to emulate. gb is Gameblaster.
121# Possible values: sb1, sb2, sbpro1, sbpro2, sb16, gb, none.
122# sbbase: The IO address of the soundblaster.
123# Possible values: 220, 240, 260, 280, 2a0, 2c0, 2e0, 300.
124# irq: The IRQ number of the soundblaster.
125# Possible values: 7, 5, 3, 9, 10, 11, 12.
126# dma: The DMA number of the soundblaster.
127# Possible values: 1, 5, 0, 3, 6, 7.
128# hdma: The High DMA number of the soundblaster.
129# Possible values: 1, 5, 0, 3, 6, 7.
130# sbmixer: Allow the soundblaster mixer to modify the DOSBox mixer.
131# oplmode: Type of OPL emulation. On 'auto' the mode is determined by sblaster type. All OPL modes are Adlib-compatible, except for 'cms'.
132# Possible values: auto, cms, opl2, dualopl2, opl3, none.
133# oplemu: Provider for the OPL emulation. compat might provide better quality (see oplrate as well).
134# Possible values: default, compat, fast.
135# oplrate: Sample rate of OPL music emulation. Use 49716 for highest quality (set the mixer rate accordingly).
136# Possible values: 44100, 49716, 48000, 32000, 22050, 16000, 11025, 8000.
137
138sbtype=sb16
139sbbase=220
140# irq=7
141irq=5
142dma=1
143hdma=5
144sbmixer=true
145oplmode=auto
146oplemu=default
147oplrate=44100
148
149[gus]
150# gus: Enable the Gravis Ultrasound emulation.
151# gusrate: Sample rate of Ultrasound emulation.
152# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
153# gusbase: The IO base address of the Gravis Ultrasound.
154# Possible values: 240, 220, 260, 280, 2a0, 2c0, 2e0, 300.
155# gusirq: The IRQ number of the Gravis Ultrasound.
156# Possible values: 5, 3, 7, 9, 10, 11, 12.
157# gusdma: The DMA channel of the Gravis Ultrasound.
158# Possible values: 3, 0, 1, 5, 6, 7.
159# ultradir: Path to Ultrasound directory. In this directory
160# there should be a MIDI directory that contains
161# the patch files for GUS playback. Patch sets used
162# with Timidity should work fine.
163
164gus=true
165gusrate=44100
166gusbase=240
167# gusirq=5
168gusirq=7
169gusdma=3
170ultradir=C:\ULTRASND
171
172[speaker]
173# pcspeaker: Enable PC-Speaker emulation.
174# pcrate: Sample rate of the PC-Speaker sound generation.
175# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
176# tandy: Enable Tandy Sound System emulation. For 'auto', emulation is present only if machine is set to 'tandy'.
177# Possible values: auto, on, off.
178# tandyrate: Sample rate of the Tandy 3-Voice generation.
179# Possible values: 44100, 48000, 32000, 22050, 16000, 11025, 8000, 49716.
180# disney: Enable Disney Sound Source emulation. (Covox Voice Master and Speech Thing compatible).
181
182pcspeaker=true
183pcrate=44100
184tandy=auto
185tandyrate=44100
186disney=true
187
188[joystick]
189# joysticktype: Type of joystick to emulate: auto (default), none,
190# 2axis (supports two joysticks),
191# 4axis (supports one joystick, first joystick used),
192# 4axis_2 (supports one joystick, second joystick used),
193# fcs (Thrustmaster), ch (CH Flightstick).
194# none disables joystick emulation.
195# auto chooses emulation depending on real joystick(s).
196# (Remember to reset dosbox's mapperfile if you saved it earlier)
197# Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
198# timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
199# autofire: continuously fires as long as you keep the button pressed.
200# swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.
201# buttonwrap: enable button wrapping at the number of emulated buttons.
202
203joysticktype=ch
204timed=true
205autofire=false
206swap34=true
207# buttonwrap=true
208buttonwrap=false
209
210[serial]
211# serial1: set type of device connected to com port.
212# Can be disabled, dummy, modem, nullmodem, directserial.
213# Additional parameters must be in the same line in the form of
214# parameter:value. Parameter for all types is irq (optional).
215# for directserial: realport (required), rxdelay (optional).
216# (realport:COM1 realport:ttyS0).
217# for modem: listenport (optional).
218# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
219# transparent, port, inhsocket (all optional).
220# Example: serial1=modem listenport:5000
221# Possible values: dummy, disabled, modem, nullmodem, directserial.
222# serial2: see serial1
223# Possible values: dummy, disabled, modem, nullmodem, directserial.
224# serial3: see serial1
225# Possible values: dummy, disabled, modem, nullmodem, directserial.
226# serial4: see serial1
227# Possible values: dummy, disabled, modem, nullmodem, directserial.
228
229serial1=directserial realport:com1
230serial2=dummy
231serial3=disabled
232serial4=disabled
233
234[dos]
235# xms: Enable XMS support.
236# ems: Enable EMS support.
237# umb: Enable UMB support.
238# keyboardlayout: Language code of the keyboard layout (or none).
239
240xms=true
241ems=true
242umb=true
243keyboardlayout=auto
244
245[ipx]
246# ipx: Enable ipx over UDP/IP emulation.
247
248ipx=true
249
250[autoexec]
251# Lines in this section will be run at startup.
252# You can put your MOUNT lines here.
253@ECHO OFF
254# MIXER MASTER 75:75
255MOUNT C C:\GAMES -FREESIZE 1000
256# VER SET 5 0
257VER SET 7 10
258SET PATH=C:\;C:\DOS;C:\FED;C:\GM_RESET;C:\NC;C:\NE;C:\NU;C:\PATH;C:\PKZIP;C:\TEMP;Z:\
259SET TEMP=C:\TEMP
260SET TMP=C:\TEMP
261C:
262CLS
