Jade Falcon wrote:
This will burst your bobble abit, the bots adjust there skill to match yours. The better you are the better they are, the worse you are the worse they are. As you get better the bots will to.
When I was playing against the bot "Archon", he was picking up an invisibility powerup (which was probably the one on the crate that I couldn't jump up to get to), and he'd walk right up to me without attacking, almost as if he was checking if I could see him or not. As soon as I'd spot him and start firing, he'd switch into attack mode. Kinda creepy. 😀
The funny thing was, I started guarding that power up so he couldn't turn invisible, then I started getting the upper hand, but by then it was too late. He won 30-16.
If I can figure out how to get to that powerup, I might be able to beat him.
