First post, by DosFreak
- l33t++
http://www.linuxgenuineadvantage.org/
Linux Genuine Advantage™ is an exciting and mandatory new way for you to place your computer under the remote control of an untr […]
Linux Genuine Advantage™ is an exciting and mandatory new way for you to place your computer under the remote control of an untrusted third party!
According to an independent study conducted by some scientists, many users of Linux are running non-Genuine versions of their operating system. This puts them at the disadvantage of having their computers work normally, without periodically phoning home unannounced to see if it's OK for their computer to continue functioning. These users are also missing out on the Advantage of paying ongoing licensing fees to ensure their computer keeps operating properly.
To remedy this, we have created a new program available as a required free download: Linux Genuine Advantage™! Statue of mariner with albatross hanging around his neck
Albatross squawking violently at another albatross Linux Genuine Advantage™ works by checking our licensing server periodically to make sure that the copy of Linux you are running is Genuine. This is determined by whether you have paid us the appropriate licensing fees. If you are out of compliance, and are past the grace period, logins to your machine will be disabled until the license fees are paid. How to log in to enter the license key when logins are disabled is left as an exercise for the reader.
Finally! Linux users can experience a feature that until now remained the exclusive domain of proprietary software.
Once you've installed Linux Genuine Advantage™, you'll want to register and send in your licensing fees to receive these important benefits:
* Your computer, which worked just fine before, will continue functioning normally!
* Our software which you just installed will not disable logins on your computer (as long as our license server keeps working properly)!
* It's totally awesome!
* We might not raise the yearly licensing fees in the future!Plus, if you act now, we promise not to launch unfounded lawsuits against you, slander you or our competitors in the press and the courts (possibly by using other smaller companies as pawns), or require you to pay us for software you won't use on every new computer you buy!
get the Linux Genuine Advantage! (with picture of soaring albatross)
Did you wake up this morning and say "I wish someone would figure out a way to let me do less with my computer"? You've come to the right place!
