First post, by DosFreak
Forum thread: http://masseffect.bioware.com/forums/viewtopi … &forum=125&sp=0
ArsTechnica Forum Thread:
http://episteme.arstechnica.com/eve/forums/a/ … /m/306006902931
Mass Effect uses SecuROM and requires an online activation for the first time that you play it. Each copy of Mass Effect comes with a CD Key which is used for this activation and for registration here at the BioWare Community. Mass Effect does not require the DVD to be in the drive in order to play, it is only for installation.
After the first activation, SecuROM requires that it re-check with the server within ten days (in case the CD Key has become public/warez'd and gets banned). Just so that the 10 day thing doesn't become abrupt, SecuROM tries its first re-check with 5 days remaining in the 10 day window. If it can't contact the server before the 10 days are up, nothing bad happens and the game still runs. After 10 days a re-check is required before the game can run.
Please feel free to ask any follow up questions in this thread and I will try and answer them when I can.
Guess I'll be waiting for the crack before I buy. 🙁
WTF happened to BioWare? WHY BIOWARE WHHHHYYYYYYYY!!!!?????
Make your games work offline
Reply 1 of 41, by leileilol
Registration at the Bioware community too? Wow they're pushy
Reply 3 of 41, by eL_PuSHeR
Frigging shitte. That's the way of encouraging people to buy games and discourage hackers. Bad. Very bad. 😠
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 41, by DosFreak
I went through all 13 pages of the BioWare thread and whipped up this FAQ:
From this thread: Part 1 http://masseffect.bioware.com/forums/viewtopi … orum=125&sp=180
and the continuing thread Part 2 up to page 8
Is there a label on the box notifying the user that activation is required?
There is the standard confusing "Internet connection required for gameplay" in the System Requirements on the box.
What kind of copy protection is being used?
SecuROM
Does the game use CD Keys?
Yes, each copy of the game comes with a CD Key that is required for activation and registration at the BioWare Community site.
Does the game require the DVD in the drive to play the game?
No, the DVD is just required to install the game.
How does the Activation process work?
#1 Requires Activation on first execution of the game (which will happen automatically). Game activates with EA SecuROM servers.
#2 Re-checks with the servers in 5 days within the 10 day window when you start the game. (Otherwise would only check once every 10 days)
If you are connected to the net at the time you start the game then it will re-auth with the servers and reset the counter.
If you are offline then the game will still work because you have 5 days left.
From Day 1 to Day 10 if you activated the game on first execution then you can play the game without re-authenticating for 10 days. On the 11th day if you have not re-authenticated then the game will not run until you do.
The game can be activated only three times. (This is the initial activation not the re-authentication).
If you try to activate after the three activations then it will not activate. For issues you will have to contact EA tech support.
The Activation used by Mass Effect does not download anything to your system.
The Activation process uses a "Normal" port.
The game must re-authenticate with the EA SecuROM servers every 10 days.
Mass Effect uses the same activation system as Direct2Drive and Jade Empire purchased through the BioWare Store.
The game can be activated on three different computers.
The activation/re-authentication is not region specific.
Changing memory from 1GB to 2GB or changing hard drive may not require re-authentication. Supposedly one or two changes will not trigger re-authentication.
Authentication is fast, invisible, and requires no direct action on the user's part after initial installation of the game.
If you have a dual-boot then you will likely have to use up 2 activations if you install the game on each OS.
You only need an Internet Connection every days 10 days in which you are actively playing the game.
The counter seems to be checked on every execution of the game.
SecuROM does not care about internal game days. Just system calendar days or perhaps the SecuROM internal day check.
"If I reformat my computer will I have to reactivate?"
If you reformatted and reinstalled the game, then almost everything would be the same and the system would most likely just re-activate without any issues. I can't give a definative answer as there are a few more variables in this situation.
If I have issues with activation of the game should I contact EA or BioWare?
EA are the ones hosting the SecuROM servers and are the ones that should be contacted.
Will the re-authentication require me to do anything?
When you execute the game the re-auth takes mere moments during game startup. There are no dialogs, no progress bars, nothing to enter or confirm. It just goes.
Does SecuROM install anything on my system?
There are no external programs with SecuROM. It is completely contained in the wrap of the executable. There are no other programs or processes that run, other than was is with MassEffect.exe
Do you have to connect to the Internet to install the game?
No, an Internet connecting is not required to INSTALL the game.
What kind of information is transmitted by the activation/re-authentication process?
It is not known what information is transmitted. Supposedly just the CD Key and a unique machine identifier.
Will EA be able to handle this authentication system?
EA has assured us that they have their auth systems and customer support staff in place and ready for the launch of Mass Effect PC. Anyone having issues with getting MEPC activated will be able to contact EA Support and get their problem resolved.
What happens if the authentication system does not work for me?
I would suggest that you contact EA Support the moment this happens (once you get your internet back) to report the issue. If there are people having problems with the system as designed, then Support needs to hear about it so they can help us evaluate it for the next game title.
What happens EA goes out of business or decides to shut down the activation servers?
Then we will release an update to remove the activation.
If I want to play the game in 10 years will I still be able to play the game?
Yes, either the activation servers will still be working or we will have released an update to remove the activation requirement.
Is the activation requirement mention in the EULA?
Yes and the EULA is on the root of the Mass Effect DVD.
Will I have to register at the BioWare Community Site to download the DLC "Bring Down the Sky"?
Yes, and it is also free for all registered Mass Effect users with a valid Mass Effect CD key.
Do I have to register at the BioWare Community Site to play the game?
No.
"What are the odds of my key being banned due to someone on the internet using a keygen?"
I believe the last time we calculated it, the odds were about 1 in 3billion of getting a valid existing CD key through a keygen
"Will the call center speak my language?"
The tech support people are American and will speak English.
Is the digital copy of the game at the EA Store the same as the retail version?
Yes, they are exactly the same. They share the same executables.
MISC INFO
SECUROM MInicom driver that runs in RING0?
test Drive Unlimited Open Beta used internet based SecuROM that was bypassed by changing the system date.
What type of activation system will Spore use?
The same one as Mass Effect.
Reply 6 of 41, by F2bnp
Yeah they fucked it up again.So yeah get the picture:Buyers will have to fight with this shit and illegal downloaders won't have to put up with it.Is this fair?
Reply 7 of 41, by DosFreak
heh. The latest thread on the activation is 39 pages long not counting the 2 previous threads (8 and 13 pages).
http://masseffect.bioware.com/forums/viewtopi … 28724&forum=125
I've also seen this news all over the internet. Type in "Mass Effect and activation" or DRM or SecuROM.
Rock Paper Shotgun has an 140 comments on it and it's a pretty good read.
Reply 8 of 41, by Xian97
That's what concerns me. I doubt if it would be high on the list of priorities for a company going out of business to pay people to create such an update. Of course, the "unofficial" patch to remove it will be out in days after the release so it might not matter, but I still don't like the idea of having to trust them to provide it since they sure don't trust me as a paying customer. It's a two way street.
Obviously the people that frequent here play old games even decades after their original release so this is a big concern for me. See also, Plays For Sure.
Reply 9 of 41, by v0g0ns
The solution is simple. If you pre-ordered this game, cancel your pre-order. If you havent pre-ordered but intended to buy this, don't. Have the pc flavor of this game flop big time. They'll probably listen then.
Rise of the Triad forum
Reply 10 of 41, by v0g0ns
DosFreak wrote:
heh. The latest thread on the activation is 39 pages long not counting the 2 previous threads (8 and 13 pages). […]
51 pages long as of now.
Reply 11 of 41, by DosFreak
70 Pages
Whoah. Glad that thread isn't hosted here......
To put a monetary value on it if you assume that each reply is a seperate user who will not buy Mass Effect (which isn't true of course), then 1,000 x $50 = $50,000 lost.
and that's just one thread on the internet......and it's only been 2 days.
Reply 12 of 41, by v0g0ns
I just thought of something. What if someone starts an online petition of some sorts, but instead of having people leave their signatures to ask for something they just put their names there to acknowledge that those people (the undersigned) will not buy mass effect for the pc. It'd be interesting to see how many signatures that document collect.
Reply 14 of 41, by v0g0ns
I've heard that line before lots of times. It's true i know, but it wouldnt be a petition. It wouldnt be asking EA to kindly remove the DRM from mass effect. it wouldnt be asking anything at all. It'd just be a testament of how many people won't definitely buy it in the first place.
Reply 15 of 41, by Snover
And a 50+ page forum thread of people actually saying "I won't buy this" doesn't achieve this goal.. how?
Yes, it’s my fault.
Reply 16 of 41, by v0g0ns
Because most of it can and most likely will be made of the same person posting 50+ posts about how much EA's copy protection scheme sucks and then logoff, turn off his pc, and head out to bestbuy to get his mass effect for the pc.And then pause between game scenario loading screens to post a little more about how much inconvenient this DRM is to legit users and how theyre done with EA.
Reply 18 of 41, by MiniMax
Rank Moderator
Moderator
People need to put their money where their mouths are.
I am sure there is several worthy causes that could need a donation, like $5 through PayPal. Make the donation, and send a copy of the receipt to EA saying "I made this donation in protest of ..........".
If EA gets 50,000 such letters, I am sure it will make a much bigger impression than a petition with 10 x times that number of names.
Edit: Here is one worthy cause:
http://www.dosbox.com/
_________________
Reply 19 of 41, by v0g0ns
*rushes out to the bank to withdraw 10000$ to donate to dosbox*
