First post, by DosFreak
http://www.rockpapershotgun.com/2008/09/04/al … -even-enforcer/
http://www.shacknews.com/laryn.x?id=17846108# … anchor_17846108
STEAM individual Game List:
http://www.steampowered.com/v/index.php
STEAM X-COM Complete Pack:
http://storefront.steampowered.com/v/index.ph … a=sub&SubId=964
By: jason bergman This person is cool! x Show Full Post Reply X-COM MENZ: […]
Reply
X-COM MENZ:
The whole series is now live on Steam!
I posted this yesterday after a brief false alarm, but they're live now.
Some details on what versions we put up there:
1) UFO Defense: This is the DOS-based version of 1.4. We use DOSBox
2) Apocalypse: Retail version, also running DOSBox.
3) Interceptor: version 1.2 for Windows
4) Enforcer: 1.0 for Windows
All have been tested and run fine in Vista.
TFD is still the Windows version, but I do intend to update that to use DOSBox at some point so we get Vista compatibility.
$4.99 each, whole series for $15, 10% off for the first week.
Make your games work offline
Reply 1 of 23, by MiniMax
Rank Moderator
Moderator
I like this from the thread at ShackNews:
Modulus wrote:
So do you guys license DOSBox? I hope the DOSBox guys are getting a nice donation from Valve.
jason bergman wrote:
On every DOSBox project I've done (X-COM, Colonization, RRT) I've worked directly with the team for tweaks/testing. They're GREAT. I send them swag.
It's shameful how Sierra and other companies have dealt with them in the past. Sierra never even contacted them when making those adventure game compilations.
_________________
Reply 3 of 23, by MiniMax
Rank Moderator
Moderator
http://www.shacknews.com/laryn.x?story=54575
_________________
Reply 4 of 23, by DosFreak
Well I bet we'll see a ton more downloads of DOSBox from sourceforge now. I see alot of people on various forums asking if DOSBox can work with other games. heh. You'd think everyone would know about DOSBox by now. Guess not.
From the above link.
modulus Who has the source code? Is it just lost? that would be sad. […]
modulus
jason bergman
Long lost, I'm afraid. When we acquired the franchise it had already changed hands many, many, many times.
Similarly, we don't have the source code to any Sid Meier title prior to Civilization 3. Sid had them all on a laptop that he lost years ago.
Nice.
Qbix, you'd better be checking in your code nightly!
Reply 5 of 23, by DosFreak
http://www.escapistmagazine.com/news/view/860 … -Comes-To-Steam
and unless you happen to be reading this on a 286 with less than four megabytes of RAM, you have zero worries about system requirements.
Great. Just great.
Reply 6 of 23, by Qbix
Rank DOSBox Author
DOSBox Author
Got some nice T-Shirts and some other merchandise. It is a nice gesture.
Water flows down the stream
Reply 7 of 23, by MiniMax
Rank Moderator
Moderator
So ... Who did the X-COM thing?
_________________
Reply 9 of 23, by DosFreak
Like Colonization which we did awhile ago and which will someday in the far future be on the net.
Reply 10 of 23, by olemogamer
A recent issue of PC Gamer had your "dosboxed" version of Colonization on it's demo disc.
Reply 11 of 23, by DosFreak
Yep, but 2K is going to release it on the net sometime between now and the heat death of the universe.
Reply 12 of 23, by swaaye
Great. Just great.
Heh. Yeah you probably need a 900 MHz P3 or better to run it well. I ran XCom in DOSBOX on a 1GHz P3 and it did ok.
What do you guys to do test the game for them? I remember X-Com running too fast in some spots but slower in others, such as the Geoscape vs. the tactical combat. It seemed stable enough though. That was about 2 years ago now so it was an older version of DOSBOX.
Reply 13 of 23, by F2bnp
Oh man...I hope this means a revival of the series soon.I loved the first one and I also liked the 3rd too much.They were the best TB Strategy games ever.Well put Master of Orion II in those 😜
Reply 14 of 23, by DosFreak
Anyone know what the "output=" line is set in dosbox.conf for the Steam X-COM games? I'm seeing a couple of people in different forums having issues with "corrupted graphics". Almost all of the posts don't have system specs or dosbox configs so it's hard to tell what's going on. They are probably all using Vista with crappy intel video cards and drivers.....
Reply 15 of 23, by MiniMax
Rank Moderator
Moderator
I saw the config posted somewhere....
Edit: But my google-foo is weak today so I can't seem to find it.
_________________
Reply 16 of 23, by Sharies
Hello, I recently bought the x-com pack from steam and using vista. Tried running apocalypse I set it up to run in window mode and it runs fine but in fullscreen I get flicker and corrupted graphics an choppy sound.
Running Vista 64 Ultimate
Geforce 9600gt
latest drivers
Xfi soundblaster card
Settings for dosbox.conf are
[sdl]
# fullscreen -- Start dosbox directly in fullscreen.
# fulldouble -- Use double buffering in fullscreen.
# fullresolution -- What resolution to use for fullscreen: original or fixed size (e.g. 1024x768).
# windowresolution -- Scale the window to this size IF the output device supports hardware scaling.
# output -- What to use for output: surface,overlay,opengl,openglnb,ddraw.
# autolock -- Mouse will automatically lock, if you click on the screen.
# sensitiviy -- Mouse sensitivity.
# waitonerror -- Wait before closing the console if dosbox has an error.
# priority -- Priority levels for dosbox: lowest,lower,normal,higher,highest,pause (when not focussed).
# Second entry behind the comma is for when dosbox is not focused/minimized.
# mapperfile -- File used to load/save the key/event mappings from.
# usescancodes -- Avoid usage of symkeys, might not work on all operating systems.
fullscreen=true
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
# language -- Select another language file.
# memsize -- Amount of memory dosbox has in megabytes.
# machine -- The type of machine tries to emulate:hercules,cga,tandy,pcjr,vga.
# captures -- Directory where things like wave,midi,screenshot get captured.
language=
machine=vga
captures=capture
memsize=32
[render]
# frameskip -- How many frames dosbox skips before drawing one.
# aspect -- Do aspect correction, if your output method doesn't support scaling this can slow things down!.
# scaler -- Scaler used to enlarge/enhance low resolution modes.
# Supported are none,normal2x,normal3x,advmame2x,advmame3x,hq2x,hq3x,
# 2xsai,super2xsai,supereagle,advinterp2x,advinterp3x,
# tv2x,tv3x,rgb2x,rgb3x,scan2x,scan3x.
frameskip=0
aspect=false
scaler=normal2x
[cpu]
# core -- CPU Core used in emulation: normal,simple,dynamic,auto.
# auto switches from normal to dynamic if appropriate.
# cycles -- Amount of instructions dosbox tries to emulate each millisecond.
# Setting this value too high results in sound dropouts and lags.
# You can also let DOSBox guess the correct value by setting it to max.
# The default setting (auto) switches to max if appropriate.
# cycleup -- Amount of cycles to increase/decrease with keycombo.
# cycledown Setting it lower than 100 will be a percentage.
core=auto
cycles=auto limit 100000
cycleup=500
cycledown=20
[mixer]
# nosound -- Enable silent mode, sound is still emulated though.
# rate -- Mixer sample rate, setting any devices higher than this will
# probably lower their sound quality.
# blocksize -- Mixer block size, larger blocks might help sound stuttering
# but sound will also be more lagged.
# prebuffer -- How many milliseconds of data to keep on top of the blocksize.
nosound=false
rate=22050
blocksize=4096
prebuffer=14
[midi]
# mpu401 -- Type of MPU-401 to emulate: none, uart or intelligent.
# device -- Device that will receive the MIDI data from MPU-401.
# This can be default,alsa,oss,win32,coreaudio,none.
# config -- Special configuration options for the device. In Windows put
# the id of the device you want to use. See README for details.
mpu401=intelligent
device=default
config=
[sblaster]
# sbtype -- Type of sblaster to emulate:none,sb1,sb2,sbpro1,sbpro2,sb16.
# sbbase,irq,dma,hdma -- The IO/IRQ/DMA/High DMA address of the soundblaster.
# mixer -- Allow the soundblaster mixer to modify the dosbox mixer.
# oplmode -- Type of OPL emulation: auto,cms,opl2,dualopl2,opl3.
# On auto the mode is determined by sblaster type.
# All OPL modes are 'Adlib', except for CMS.
# oplrate -- Sample rate of OPL music emulation.
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
# gus -- Enable the Gravis Ultrasound emulation.
# gusbase,irq1,irq2,dma1,dma2 -- The IO/IRQ/DMA addresses of the
# Gravis Ultrasound. (Same IRQ's and DMA's are OK.)
# gusrate -- Sample rate of Ultrasound emulation.
# ultradir -- Path to Ultrasound directory. In this directory
# there should be a MIDI directory that contains
# the patch files for GUS playback. Patch sets used
# with Timidity should work fine.
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandy -- Enable Tandy Sound System emulation (off,on,auto).
# For auto Tandysound emulation is present only if machine is set to tandy.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
# disney -- Enable Disney Sound Source emulation.
pcspeaker=true
pcrate=22050
tandy=auto
tandyrate=22050
disney=true
[joystick]
# joysticktype -- Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks), 4axis,
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# timed -- enable timed intervals for axis. (false is old style behaviour).
# autofire -- continuously fires as long as you keep the button pressed.
# swap34 -- swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap -- enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=true
[serial]
# serial1-4 -- set type of device connected to com port.
# Can be disabled, dummy, modem, nullmodem, directserial.
# Additional parameters must be in the same line in the form of
# parameter:value. Parameter for all types is irq.
# for directserial: realport (required), rxdelay (optional).
# for modem: listenport (optional).
# for nullmodem: server, rxdelay, txdelay, telnet, usedtr,
# transparent, port, inhsocket (all optional).
# Example: serial1=modem listenport:5000
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
# xms -- Enable XMS support.
# ems -- Enable EMS support.
# umb -- Enable UMB support.
# keyboardlayout -- Language code of the keyboard layout (or none).
xms=true
ems=true
umb=true
keyboardlayout=none
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
# Lines in this section will be run at startup.
@echo off
mount c . -freesize 1024
imgmount d cd.iso -t iso
c:
cd xcoma
xcomapoc.exe
exit
Reply 18 of 23, by MiniMax
Rank Moderator
Moderator
You could try chaning output=surface to output=ddraw
_________________
