First post, by ncmark
Hey All,
I have a very puzzling problem and was hoping someone could shed some light on it.
I was running Turbo Assembler (TASM) 2 under windows 98 and had written a program to read and write individual floppy disk sectors using the BIOS call.
Now after building a real DOS box - the program will not run!!!! I stripped it down to minimum code and as far as I can tell it just won't call the BIOS function properly.
Now the machine is a pentium 3 downclockled to 375 (bus set down to 66).
I am starting to think the problem is DOS itself - I booted on this machine and another from a floppy - so no disk cache, no memory program, no mouse - and it STILL did it.
I thought all CPUs were backwards compatible, but I'm starting to think the problem is DOS on a pentium 3.
I have also had some other programs that will not run, or give me some strange error messages about protected mode.
All the games - like DOOM, DUKE3d, Radix - all work just fine.
Any suggestions?
