First post, by Tetrium
- l33t++
Just a quick question:
With XP, installing a NIC (=network card) is easy. Just install, start your computer and it's all done, nice and easy 😁
But even though I've used ME in the past quite a lot, I never tried to network 2 ME rigs together so I have a couple questions maybe someone here knows
1)Does ME have the same easy NIC installation process as XP, in that you install the NIC and off you go? Or will I need to hunt down compatible drivers for every NIC I try to use?
2)Are there any particular problems I should be aware about when networking 2 ME rigs together?
I won't bother using a firewall, these will be offline rigs for playing old games like Interstate and Z in a LAN
Anyone happen to be a guru at this?
Thanks!
