First post, by ratfink
- Oldbie
Can anybody recommend a piece of hardware [internal card or otherwise] that would enable me to:
- convert camcorder VHS videotape [my VHS camcorder has RCA jacks] to DVD format
- convert 8mm digital tape to DVD format. My 8mm camcorder has a cable that ends with the same 3 RCA jacks as I recall.
Mainly I want something that's going to preserve as much of the original material as possible. This is old family videos.
I've got a Adaptec usb device from probably over 5 years ago, which used to lose the signal from the vhs camcorder when the scene changed, so was utterly useless as it mostly just recorded static. Then I got a Hauppauge WinTV PVR 150, but I'm having trouble getting that to install at the moment. So, looking for recommendations for something that might "just work".
Prefer something that runs on a PC, preferably under either 2000 or 7 64-bit. But open to suggestions! Doesn't have to be a PCI card.
