Reply 20 of 29, by Mau1wurf1977
- l33t++
wrote:Would my bases be covered?
Yes!
How would I switch b/w general MIDI and MT-32 MIDI given they both use the same port (330)? Is this just an internal/external option being switched in the SCC-1's software?
Both MIDI devices will play at the same time (if the Game is General Midi the MT-32 will sound wrong and if the Game is MT-32 the SCC-1 will sound wrong).
So yes it's just a matter of muting one and the other using the SB16 mixer.
A 3 channel Stereo mixer would solve all this. Then you can configure the mixer to mute MT-32 for General MIDI + SB 16 games and mute General MIDI for SB 16 + MT-32 games.
OR use a 2 channel Stereo switchbox to feed the MT-32 and General MIDI signals into the line-in of the Sound Blaster.
I also plug things in manually as I do recordings as well and every scenario can be totally different.
Note that the SB16 has more inputs than just line-in. There is AUX and CD but they are on the board so you would need to build some cables.
