Reply 120 of 321, by collector
- l33t
wrote:I still miss the XP explorer thing: Up Button, explorer pane, triangles etc.
There are several interface enhancements that 7 has that by now I find it a bit of a pain going back to XP. I love the previews of open items on the Taskbar, thumbnails for icons on the desktop, Aero Shake and jumbo high res icons. A Windows Explorer folder now makes a pretty good photo management program. Windows Key+Tab does a more graphical Alt+Tab.
The changes to the folder navigation I feel are a step forward. The Win7 folders have both a back and forward buttons. The up button is not needed as the addressbar uses bread crumbs to be able to instantly navigate to any higher folder in the path with a single click. If by explorer pane you mean the navigation pane or fodler treeview, it is still there, you just have to turn it on (Organize > Layout) You can also turn the Menubar back on.
Mind you, that I still like a couple of things in the XP interface better, but with a few tweaks the only thing that I miss is the original XP search and the ability to arrange items in the start menu and folder icons. The ability pin items in the Start Menu lessens my desire about the Start Menu.
BTW, in case you are not aware, you can even make the Taskbar more like XP's. The Quick Launch is still there for backwards compatibility. but is not in the list of built-in toolbars. You have to create a new toolbar and navigate to the folder.
